Hot Rods Flathead Cam and Stroke choices
Discussion in 'The Hokey Ass Message Board' started by stubbsrodandcustom, Mar 10, 2025.
  1. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    I'm in the process of building a new motor for a new project and have a few questions for the Flatty guys who have done it more than I have. I currently have a 1007B Isky in my 59a flatty in my 34 Tudor with great results and it's got a good sound and performs well. But in this new build I want a nasty sound that still performs well.
    59ab Flatty 239 is motor in question. Aftermarket heads and intake, and mild porting etc.
    Does the 4" stroke merc crank add that much in a noticeable gain to be worth the financial output for either a stock cleaned up or a ****? I know on the stock figures that van pelt has its good for 10 hp on stock heads. Is the power and torque down low or more midrange focused?
    Cam choices, I have a few buddies running 400jr's and they are pleased with them, but I have heard some Potovin 3/8 grinds online but I have known no one running one so I decided to turn to the hamb as someone here has to have run both cams and have a real-world experience between the two.
    Thanks in advance.
    Jesus likes flatheads too.
    NoSurf, Ziggster and leon bee like this.
  2. FrozenMerc
    FrozenMerc
    A couple of rules of thumb to consider first.
    Two similar engines, all other items being equal, except the stroke will make the same peak power, but the engine with the longer stroke will do it lower in the RPM range. In fact, the entire power curve will just shift lower into the rpm range. The problem you run into, is that it is impossible to get all other things equal. A longer stoke will increase piston velocity, which results in changes in rotating resistance, dwell time, volumetric efficiency, and other factors which all have an effect on the power curve.
    Longer stroke (and larger displacement in general), will dampen down a larger cam. I.E., a rowdy and knarly cam in a 250 ci engine will be much less so in a 300 ci engine.
    Flatheads are the most expensive way there is to generate 200 hp. Because of the poor volumetric efficiency of the intake tract and ***ociated low compression ratio, changes to stroke and cam, produce less gains than in a similar sized overhead valve engine. These are not necessarily bad things, just be aware that the biggest gains come from figuring out ways to increase air density within the cylinder.
  3. dan c
    dan c
    i ran a 400jr in a shoebox and it was a terror in 2nd gear from 40mph and up. dead as a doornail in town. i'd use at least 4.10 gears. oh, and check your cylinder head clearance over the valves. an 88 might be a better choice...
    acme30 and stubbsrodandcustom like this.
  4. tubman
    tubman
    Look into an L100. There are several sources, and I have heard good things.
    NoSurf and stubbsrodandcustom like this.
  5. tjm73
    tjm73
    The L100 sure has the sound thing figured out. Not sure about the rest, but I 'd love to find out.
    stubbsrodandcustom likes this.
  6. lostn51
    lostn51
    from Tennessee
    If your just wanting a cam to make some noise check out the Mutha Thumper from Comp Cams. I saw a video of an 8BA running with one and on surround sound with the volume turned way up it rattles pretty good!:D The dogs were howling and yowling, the wife was screaming for me to turn it down so it’s got to be a good’un
  7. alchemy
    alchemy
    Well where is that video?
  8. Ziggster
    Ziggster
    One of the best sounding flatheads I’ve ever come across but this is with nitro. There was another from Honest Charley with one on a test stand. Can’t seem to find it now. Hoping my 1007B cam will be “good enough”. lol!
    Speed Gems and akoutlaw like this.
  9. Kiwi 4d
    Kiwi 4d
    KiWinUS likes this.
  10. NoSurf
    NoSurf
    My 59L w 4" merc crank and L100 sounds great and moves my coupe pretty good. I'm running 10s flat in the 1/8th mile.
    My coupe at 24:24
  11. chicken
    chicken
    from Kansas
    Damn, that sounds and runs great! :)
    NoSurf likes this.
  12. alchemy
    alchemy
    I’ve got an L-100 from Kiwi sitting on the shelf. Can’t wait to build a flathead around it.
    stubbsrodandcustom and NoSurf like this.
  13. Torana68
    Torana68
    from Australia
    Long and lumpy would be my choice.
  14. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    Fun little find that I found today on the barn.
  15. krylon32
    krylon32
    from Nebraska
    I had frames on here build my current FH motor. **** 4 inch crank and Isky 88 cam. 2 carb intake. Sure ran good on the test stand.
