Technical flathead cam questions and suggestions
Discussion in 'The Hokey Ass Message Board' started by hotrodderhaag, Aug 25, 2014.
  1. hotrodderhaag
    hotrodderhaag
    i have my 37 flathead tore down and headed for the machine shop to get an overhaul.. im trying to figure out what cam i want to run. i want a very aggressive idle. Im not looking for some huge race engine build. its a mild overhaul with stock bore, aluminum heads and a valve job.
    I want to run an ISKY for sure. i was interested in the FULL RACE. some say its to aggressive to drive on the street so they suggested the 400jr. .. my question is, is anyone running a full race on the street? do i need different valve springs to match the cam? and how about a 4oo jr? or is there other cams anyone suggest?
    this is my first flathead build.. I dismantled the engine and its a bare block headed to the shop today.
    thanks guys
  2. Texas Webb
    Texas Webb
    Ask over on the Barn also.
  3. hotrodderhaag
    hotrodderhaag
    also,
    it has a mcculloch supercharger and dual carbs,
  4. Russco
    Russco
    from Central IL
    Check with Pete1 for a cam choice and see if he will grind it for you. If you do end up with an Isky. I strongly suggest you degree it for accuracy. I have one of their 300 dollar paper weights that's never been ran in my ba*****t.
    primeisnotacrime likes this.
  5. roseville carl
    roseville carl
    X2 on Pete 1 just tell him what you expect it to do and listen...........
  6. Hotrodmyk
    Hotrodmyk
