Technical Flathead carburetor idle mixture
Discussion in 'The Hokey Ass Message Board' started by FTreadway, Feb 21, 2017.
  1. FTreadway
    FTreadway
    I rebuilt my model 59 carburetor and adjusting the idle mixture screws all the way in or all the way out changes nothing. The engine is idling rich (black smoke from both exhausts). I know the first thought is blocked or restricted internal p***ages. I have been through this carb 3 times now and there are no blocked p***ages. Any ideas??
  2. big duece
    big duece
    from kansas
    Float level may be too high, as well as fuel pressure.
  3. Could be wrong gasket on the power valve (or late model PV and its leaking fuel, ^ should be running around 3 PSI fuel pressure. the Power valve should have a flat face with NO taper where the gasket sits. If it has a taper it will not full seat and leak. There is a thick gasket that will seal this type of power valve in a 94/59 carb
  4. FTreadway
    FTreadway
    The carb kits I bought came from NAPA. The kits had 2 power valves. I installed the one that looked the closest to the one removed when I initially rebuilt the carb. I've been reading some articles on power valves and found there are different ones identified by a specific number. My flathead is basically stock except for being bored .030 over. How would I know which power valve to install when the ones in the kits have no numbers stamped on them? I don't know what my fuel pressure is, but I will be installing a fuel pressure gauge soon to find out.
  5. RICK R 44
    RICK R 44
    Post your questions on Ford Barn. There is a wealth of flathead info on that sight
  6. clem
    clem
    Usually 7.5 power valve for stock, single carb.
    Number (usually) stamped on the side.
    Spring tension is the difference in different PVs. (From what I can see)
    Also different styles of PVs that do and don't fit.
    Sometimes the sealing washers don't seal, as mentioned in post 3.
    3340 likes this.
  7. carbking
    carbking
    "The carb kits I bought came from NAPA. The kits had 2 power valves. I installed the one that looked the closest to the one removed when I initially rebuilt the carb."
    Is it possible that you got one power valve and one spark valve?
    The easy way to tell the difference is that the plunger on the power valve may be pushed in, but the plunger on the spark valve may be pulled.
    Jon.
    clem and warbird1 like this.
  8. FTreadway
    FTreadway
    I think you are right on that. Although the valves look similar, one can be pushed in and the other has to be pulled out. Thanks!!
  9. FTreadway
    FTreadway
    I went through my new and used parts. I found one used power valve with 7.5 stamped on it. It had 2 gaskets on it. One is soft metal and appears to be lead. I cleaned the valve up and installed it in the carburetor (with both gaskets). Result: I can now adjust the idle mixture screws; no more black smoke from the exhaust and I think it has solved my problem of gas leaking into the crankcase and diluting the oil. Today I changed the oil for the 4th time and the truck hasn't even seen the road yet!! Thanks for all the input!
  10. clem
    clem
    If the power valve has been sitting around for a while the rubber may be close to perishing.
    It would still pay to put a new one in.
  11. FTreadway
    FTreadway
    You're right, Clem. That is something I will do prior to this thing getting on the road. At least I know now how to solve the problems I was having. Thanks!!
  12. Petejoe
    Petejoe
    from Zoar, Ohio
    Agree with above. If you find no changes when tightening up your idle screws normally you have a vacuum leak.
