Hi all, I just put 10´clutch on the engine and when mounted, there is cca 3 mm axial play on one of three clutch fingers. This finger is marked "F" - if it does mean anything. I took this clutch assembly from the box, it seems to be NOS, professionaly refurbished some long time ago and never used since, so I think it should be OK. I can feel this play when the clutch is mounted on the flywheel, clutch disc is brand new. So, what could be wrong, if any? Pivot pin looks fine, so the lever itself. Please, advice. Myny thanks in advance!
