flathead clutch question
Discussion in 'The Hokey Ass Message Board' started by remy824, Feb 11, 2011.
  1. remy824
    remy824
    from mass
    what size clutch and pressure plate does my 59-ab flathead with a 39 trans take and were can i get one ebay does not seem to have any on thanks
  2. Jimmy2car
    Jimmy2car
    from No. Cal
    All 59 car engines were 10". Some, maybe all trucks 11". Mac's Antique Auto Parts and many others carry them. Might even try a local NAPA store. There are also some very good rebuilders out there
  3. remy824
    remy824
    from mass
    well my flathead motor was a generator so i dont know if it was a car or a truck motor
  4. FlatheadFanFromMI
    FlatheadFanFromMI
    it really doesn't matter where the motor came from. you just need the correct clutch/pressure plate for your application. trucks must use longer pedals than cars, cause i had the wrong one in my coupe and could barely hold the pedal down!
  5. big bad john
    big bad john
    .....10" or 11" whatever matches the pressure plates.......you can find them at local parts store or order them from Ford Barn, Mac's, or other Ford catalogs
  6. pigpen1
    pigpen1
    got mine at napa
  7. thunderbirdesq
    thunderbirdesq
    Napa has them, just bought a 10" clutch and pressure plate there for mine not long ago.
  8. remy824
    remy824
    from mass
    what year did you tell them?
  9. Got mine at NAPA...
  10. Slick Willy
    Slick Willy
    remy824 where are you in MA? there are several shops that would have what you need on the shelf and guys that would be willing to help
  11. Fortyfordguy
    Fortyfordguy
    We stock the repro 10" Ford clutch and pressure plates. If your engine was direct bolted to a generator, it may have a special flywheel on it.....something that is not drilled for the usual 10" clutch setup. However, any 59A type p***enger car flathead would have had that 10" clutch and the flywheel would work. If it was from a truck, it probably had the 11" flywheel, so watch what you buy. I should also have one or two of the 59A flywheels here. Let me know if you can't find what you need.
  12. remy824
    remy824
    from mass
    i live in ***onet , ma right next to taunton
  13. Slick Willy
    Slick Willy
    you can try freemans in norton...i heard hes closed for a few weeks but he will have it
  14. doctorZ
    doctorZ
    we stock the complete ***emblies (clutch, pressure plate, flywheel) lightened and balanced. a 10" will be just fine for a hot rod.
  15. Mr48chev
