Technical Flathead clutch won't disengage
Discussion in 'Traditional Hot Rods' started by FlatJan, Sep 3, 2018.
  1. FlatJan
    FlatJan
    hi
    i don't know why but my clutch won't disengage. If i rotate the clutch shaft to the max it just touches the 3 bolt for disengagement
    i have French flathead and a 39 ****** with a new release bearing.
    can anybody tell what's wrong?
    is the french pressure plate incompatible?
    pictures show the clutch shaft in released position.
    thanks Jan
  2. christmas tree
    christmas tree
    Clutch disc in backwards?
  3. weathrmn
    weathrmn
    I went nuts for over a year with a similar problem. Turned out to be a transmission was from a 6cyl flathead. The case is different. To check, look for a 1/4 hole in the bottom of the case.For a V8 case, this hole allows you to insert a long drift to drive out the pin in the throwout bearing fork. If that hole isn't in the bottom of the case, it's a 6cyl. trans
    FlatJan likes this.
  4. init1
    init1
    Does the French pressure plate look like a Ford 3 arm stock plate?
    I think it might be the pressure plate is not compatible with the Ford disc.
  5. Cliff Ramsdell
    Cliff Ramsdell
    Well, you didn’t say what vehicle this is in.
    How about a shot of the pedal and linkage setup you have?
    Maybe a combination of the wrong linkage parts.
    Cliff Ramsdell
  6. Pete Eastwood
    Pete Eastwood
    from california
    the clutch fingers are up against the candle stick, they aren't even close to the throw out bearing !
    Looks like the pressure plate is wrong , the fingers are to long & to close to the center !
  7. Cliff Ramsdell
    Cliff Ramsdell
    Pete makes a good point. Looking at the picture closer the fingers could be hitting on the inputshaft retainer.
    Maybe the pressure plate is for a 1 1/16” input shaft and not the. 1 3/8” that the flathead uses.
    Cliff Ramsdell
  8. Cliff Ramsdell
    Cliff Ramsdell
    Jan,
    Any update to your issue?
    Cliff
  9. 55styleliner
    55styleliner
    If the clutch fork is in backwards this will occur.
  10. sfowler
    sfowler
    clutch fork is in correctly but appears to have the wrong pressure plate
  11. WillH
    WillH
    from Texas
    Throw out bearing should just clear the three studs at rest.
