Technical Flathead connecting rod HELP!
Discussion in 'Traditional Hot Rods' started by Dynaflash_8, Jan 20, 2014.
  1. Dynaflash_8
    Dynaflash_8
    from Auburn WA
    So I'm putting together a 59a style flathead for a friend. .030, turned crank yada yada yada. Went to drop the rods on the crank and they don't fit. I'm pretty sure the rods he supplied are Babbitt rods with no Babbitt. Nobody makes aftermarket rods for the full floating, only the staked bearing 8ba style. Has the 2.139 rod journal.
    What do I do?
    Sent via my typewriter
  2. aonemarine
    aonemarine
    from Delaware
    shouldnt be babbit rods, they do take a bearing but the bearing is one shell for both rods on the journal.....
  3. Dynaflash_8
    Dynaflash_8
    from Auburn WA
    Correct. I have the incorrect rods for this motor.
  4. aonemarine
    aonemarine
    from Delaware
    ohh, so you need a set of rods?? pm 40fords, i know he has a few sets, not sure of condition though. He may have nos but you would have to ask...
  5. tig master
    tig master
    from up north
    Don't use 8ba rods on a 59a crank.
    T
  6. DICK SPADARO
    DICK SPADARO
    Wait before you do something stupid. First look on the side of the rod beam, there should be a marking in the beam-- a number and letter, What is it? This will determine the rods you have and necessary before you take any other steps.
