Hot Rods FLATHEAD CRANK SCROLL QUESTION
Discussion in 'The Hokey Ass Message Board' started by Motorvator, Sep 28, 2017.
  1. Motorvator
    Motorvator
    i have had an oil leak from the rear seal of my french block flathead since i built it .everything is new ,**** crank and rods ect. i noticed yesterday that there is no counterclockwise scroll on the crank where the rope seal sits ,all the original ford cranks i have looked at have one. i have replaced the rope seals five times and i'm sick of it.are **** cranks supposed to have the scroll? i am running a pcv valve , so the engine is breathing ,tried different oil,different rope seals ,checked bearing clearance . thanks
  2. Motorvator
    Motorvator
  3. Motorvator
    Motorvator
    Anybody had this problem?
  4. Budget36
    Budget36
  5. Motorvator
    Motorvator
    Good point ,thank you
  6. stillrunners
    stillrunners
    from dallas
    Bump - What - they run **** cranks in their flat heads over on the Ford Barn ?
