flathead distributor advice
Discussion in 'The Hokey Ass Message Board' started by sunsetcruiser, Feb 16, 2012.
  1. sunsetcruiser
    sunsetcruiser
    I have a 28 RPU that I have installed a V8-60 and trans from a 37 Ford. Received Eddie Meyer heads with it, purchased headers from Red"s and Edelbrock intake with 2 92's. Should I have Bubba do the diving bell dist or buy an aftermarket crab dist? Which would work best for me? Thanks
  2. alchemy
    alchemy
    Pick up a cheap original '42 crab distributor and have Bubba do it.
  3. Exactly.
  4. Bruce Lancaster
    Bruce Lancaster
    The diver helmets can run essentially the same works as crab, but are MUCH harder to work on...the huge helmet hits everything as you try to get it out, while the super short crab just slides right out to be tuned and timed on the workbench. You'll need an adaptor to conver the bolt pattern up front.
  5. alchemy
    alchemy
    Or a new front cover. I usually pick up the two-bolt covers at swap meets when they are under $10, and I've got a lifetime supply. They are out there.
    I think Joblot or Mac's may even sell new/NOS ones for reasonable cost as well.
    Edit: Just checked, and Mac's has the front covers for $47.
  6. Bruce Lancaster
    Bruce Lancaster
    No 2 holers for a 60!
  7. Why not rebuild a crab yourself? It's not rocket science. I just did mine.... completely stripped it and rebuilt using new parts from Macs (most of which were labelled Made In USA) and it runs like a top.
  8. sunsetcruiser
    sunsetcruiser
    Still a little confused about the adaptor/spacer. My distributor was attached to the block by 2 bolts. Does that make it a 2 bolt? Or do I still need a adaptor to get the crab to fit? Thanks to all...I'm learning!
  9. Bruce Lancaster
    Bruce Lancaster
    If you have a helmet that is OEM 60, this is a '37-41 type used on both 60 and 85...it has FOUR boltholes in distributor, 3 of which fit 60, and different choice of 3 fits 85.
    A '42-8 distributor has 2 threaded holes in front cover, 180 from each other, and a 3rd hole that is unthreaded vac connection. I do not believe a 2 bolt cover was ever made for 60... and remember last 60's in USA were produced before the crab even existed.
    Count actual holes in your cover...
  10. alchemy
    alchemy
    I guess I shoulda read all the words in the original post!
  11. onekoolkat1950
    onekoolkat1950
    have bubba rebuild it.he did mine and when i got it back it looked like new!
  12. sunsetcruiser
    sunsetcruiser
    Thanks all. I got it now. And you, Mr Lancaster, will you come live at my house during this build?
  13. Bruce Lancaster
    Bruce Lancaster
    Who's cooking? I want to see reviews.
