Any suggestions for a dual intake manifold for a 59A running a generator in the stock location? Does the Offy work with dual 94's and clear the gen? I prefer not to use the offset mount. This is in a Model A roadster. Thanks
The engine is a 59ab in the '41 pickup. The gen appears to be stock with the exception of being converted to 12 volts. There is about a half inch clearance between the front carb and gen. Both carbs are 94s. I had better luck with straight linkage. Progressive linkage proved very troublesome.
