Technical Flathead engine rebuilder north of Seattle
Discussion in 'The Hokey Ass Message Board' started by uncle buck, Nov 20, 2023.
  1. uncle buck
    uncle buck
    Any recommendations for a machine shop north of Seattle? We seem to have lost most of the experienced flathead shops over the last few years. Rob at action looks to not want to do any flatheads I am told.
  2. Mr48chev
    I've never quite understood it because in truth, they are just a simple V8 engine that needs a couple of different pieces so that you can grind the valve seats unless you get into porting and relieving the block. If anything the h***le of getting parts though normal supply chains and the more tedious process of grinding (and adjusting if you don't have adjustable lifters) the valves is the only big difference from working on a SB Chevy or Ford engine or most ohv V8 engines. On the rest of the short block every other process is going to be relatively close to the same.
    I know there will be a bunch of "But, but, but flatheads are different and you have to______" but in the real world you strip a block down, Clean it by what ever process you use, figure out what if anything is wrong that it isn't usable, and the figure out what you need to do to properly rebuild it. From there you align hone the block if needed, bore it, fit the pistons, grind the valve seats and either do what is needed on the crank or send it out or replace it plus rework the rods. Then carefully ***emble it. Thing is that many machine shops can probably do four sets of SBC heads in the time it takes to do the valve seats on one flathead block. Plus the block doesn't fit up in the fixtures that you set OHV heads in to cut the valve seats with the cutters they have now rather than grind them with stones.
    Bandit Billy likes this.
  3. RmK57
    RmK57
    Luke’s Custom Machine and Design in North Vancouver. If you’re okay going north of the border.
  4. cruxseattle
    cruxseattle
    Dave Benjamin?
    DB Hard Parts LLC · Page · Automotive, Aircraft & Boat · (425) 760-9092
  5. uncle buck
    uncle buck
    It sounds like Sedro-Woolley Carquest is willing to still do Flathead machining.
  6. DDDenny
  7. Bandit Billy
    Bandit Billy
    The problem is boring plates. Not everyone has them. I had to make a pair for my machinist out of a set of heads when I had mine built. I know a couple of good shops down here in SW Washington that can bore, relieve and build as much engine as you can afford.
    Toms Dogs likes this.
  8. uncle buck
    uncle buck
    Dave Tatum has since p***ed away
  9. Tim
    Tim
    from KCMO
  10. PackardV8
    PackardV8
    Are we talking about torque plates for honing? How much they're needed depends upon the final bore diameter. Flathead cylinders are small diameter and the walls are thick. If one is just doing a cleanup bore rebuild, the cylinders will be round without a torque plate. If doing a 3.375" a torque plate is necessary.
    jack vines
  11. Bandit Billy
    Bandit Billy
    Yeah, but I am talking about going large or going home. I took mine .125 over and had it relieved. If the OP wants that kind of work, it may be worth a drive down south.
    Toms Dogs and sidevalve8ba like this.
