Flathead Engine Stand?
Discussion in 'The Hokey Ass Message Board' started by Richard D, Oct 30, 2010.
  1. I read somewhere it is wrong to support a 59AB by the bellhousing, and to use the exhaust bolt holes instead. What about an 8BA?
  2. banjo
    banjo
    ive had my 8ba on my engine stand about 8-9 months, no prob.
  3. Should still use the exhaust. I made my stand adaptor and have the parts cut out to weld up two more. I forgot I had the pieces until the other night, I had intended on selling a couple.
  4. Mean Lean
    Mean Lean
    Home welded, perfect in balance in all positions
  5. Pete1
    Pete1
    from Wa.
    Hanging by exhaust works fine.
    Hanging by bell housing works fine. (Both 59 and 8ba)
    I have even hung flathead Lincoln V12's by the bell housing.
    Many years ago a friend brought me a 59A engine that the flywheel
    had exploded on and wiped the bell housing off completely.
    I brazed a new one on and hung the block by the bell housing to re***emble it.
    People worry too much.
  6. 4t7flat
    4t7flat
    I hung one of my 59 AB engines from the bell housing,and broke out a 2" chunk of metal. After that I bought an adaptor that bolts off of the exhaust. Someone invented that adaptor for a good reason.
  7. Flatheadguy
    Flatheadguy
    DITTO!! (I didn't break anything, but...last sentence above)
  8. Pat Pryor
    Pat Pryor
    oooo thats nice
  9. RichFox
    RichFox
    It's really a nicer way to hold an engine. You can get the flywheel on. Get anywhere on the engine you want to, I think, a little eaiser than with a bellhousing mount. I wish you could do that with all engines. Maybe I can send a note to me representive to p*** a law. Dear Ms. Boxer...
  10. Someday I am going to get one of those stands, just to have. They are beautiful.
  11. Bill Van Dyke
    Bill Van Dyke
    Seem to recall that Vern Tardel makes one similar to the old PSI side bracket. KR Wilson ones are scarce, pricey and really neat.
  12. Dale Fairfax
    Dale Fairfax
    The 8BA hangs on a conventional stand just like a SBC. No problem.
  13. I made an exhaust mount head for a regular engine stand, VERY simple and rewarding project. It is also really nice and easy spin the engine around at 90 degree intervals.
  14. flthd
    flthd
    I hung my 59a from the bell housing with grade eights all the way through with a nut.
    It didnt break but I was afraid to touch it. next time I will do it right.
  15. I'll make an exhaust mount just for fun.
  16. olcurmdgeon
    olcurmdgeon
    In the 80s we bought an 8BA from a circle track guy, engine was never run as the VT track went to 300 cu in Ford sixes. Engine came on a rotisserie type stand, both ends supported with a tray underneath for parts. Stand appeared to be a commercial one, not a home built one. Was a convenient way to handle the motor. Only one I have ever seen.
  17. tommy
    tommy
    A very nice one made by JWL on the Ford Barn. I'd make one if I had a 59A. Is it worth the risk?
  18. big bad john
    big bad john
    ......Now...that is real nice......
  19. I've always wanted to build a stand like that. Those little $39 engine stands make me nervous as Hell.
  20. Like this?
    Made of 4" sch 80, strong as a garlic milkshake!
    Small block Chevy adapter. It was originally made just to fit the SBC, but I cut it off, welded on the square, and threaded the SBC adapter to make it removable. Now I need to make a flathead adapter.
    Thanks to Unclee for donating this engine stand; I added wheels, I need to cap the ends off to give it a finished look, and then paint.
  21. plan9
    plan9
    [​IMG]this is what a KRW stand looks like.... useful site to visit if you are into KRW tools. http://krwilsontools.com/
    ive got a stand with base and original casters.... i need the parts/tool tray though. its heavy as ****.
    mctim64 likes this.
  22. Now that is a nice stand!
  23. Frenchy Dehoux
    Frenchy Dehoux
    Here is a picture of the one I build for my Lincoln V12
    Frenchy
  24. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    That's the answer I was searching for! I'm gonna make one for mine. VIVA la HAMB search feature!:D
