Technical Flathead exhaust on 32 Ford
Discussion in 'Traditional Hot Rods' started by HaroldDegand, May 2, 2021.
  1. Hi, I'm looing for infos about headers/manifold that can fit a french flathead in a stock 1932 frame.
    Also, everything is stock :
    I use steady rods, stock wishbone, mechanical brakes, steering box, 1939 trans.
    I tried a 59ab manifold, but even without gasket, manifold and steering are in contact.
    The engine in pics is a crusty 59 used only for mock-up.
    Some people recommand Red headers.
    What about the economy one from Speedway ?
    What did you fit on yours ? Pics will be very helpful.
    Thanks.
  2. big duece
    big duece
    from kansas
    I have Red's on my French block, stock frame... but using a vega box and there is a special part # for vega application.
  3. krylon32
    krylon32
    from Nebraska
    Since this is basically a restored car you might ask over on the Ford Barn.
  4. FritzJr
    FritzJr
    Stock '32 to '36 exhaust manifold should fit without interference to the steering box. The exhaust will exit near the front.
  5. AULIZ
    AULIZ
    You can see in my roaster topic how I solved that problem last week.
    130usd headers, few hours working with one primary tube.
    Then You have good headers, looks better than those lowprice "centerdump" models.
    Aulis
  6. hotrodA
    hotrodA
    Here's mine. Identical to yours.
    32 frame, 59AB, 34 box (same as 32, bolt pattern reversed). Stock exh. manifold of unknown year. Stock pedals. Uncut wishbones.
    Should have plenty of room.
    What is your front motor mount?
    Stock location fore and aft?
  7. How about Mart's latest thread
    MART'S UPDATE 2021 EP18 PT1 AND 2. PROGRESS ON THE 32.
  8. I have stock 32 front mount. My engine sit a little bit lower than yours.
    The mounts of the 8RT waterpumps are under the top of the frame rails.
  9. Andy
    Andy
    P1030468.JPG I bought the cheap Speedway headers. Everything fit except the tube by the steering box. I bolted the stock right side manifold to the left side header as a weld fixture and then cut and repositioned the pipe. They worked just fine. This was in a stock 32 frame and steering box with a flathead mounted on original mounts.
  10. Thanks Andy, that’s a good tip !
    Do you have a pic from under ? I suppose your main left tube is straight ?
  11. Mart is using Red headers and his engine sit a little bit higher than mine.
    I was looking for something cheaper. I’ve order economy ones on eBay.
