Flathead fan?
Discussion in 'The Hokey Ass Message Board' started by Flathead Lobo, Mar 6, 2006.
  1. Flathead Lobo
    Flathead Lobo
    :confused: I took apart my fan****embly on my 8BA because I could see fluid and dirt built up on it . I'm pretty dumb when it comes to flatheads. Any way what type of fluid do you put in the fan hub?:eek:
  2. Jim Marlett
    Jim Marlett
    I think none unless it has an oil cup. The fans on '49-'53 passenger cars (and I****ume all the others) are sealed self-lubricating bearings. I don't know about trucks, but it would surprise me to find they were any different. I also don't know about earlier fans that might have snuck its way onto a later motor.
  3. 51 MERC-CT
    51 MERC-CT
    Assuming you have the oil type hub, the latest I have heard is 80 weight rear end lube. Just enough to be level to the fill hole when it is horizontal.:) :D
  4. Sixcarb
    Sixcarb
    from North NJ
    Mine has just regular motor oil in it.......not sure if thats 100% correct but have not had one problem for several years since I had it apart to change the fan.
  5. I use an 8RT big turck fan, it takes 30 SAE motor oil.
  6. Flathead Lobo
    Flathead Lobo
    Thanks for the help! I couldn't find anything in my Motor Manual on it at all.:D
