flathead flywheel?
Discussion in 'The Hokey Ass Message Board' started by C. Montgomery, Feb 29, 2004.
  1. C. Montgomery
    C. Montgomery
    I'm gonna put the T-5 behind my flathead..I want to put a 10 inch clutch in it, stock is 9 1/2 inches I think I'll need a different flywheel, no? Any suggestions are appreciated..
  2. 286merc
    286merc
    from Pelham, NH
    If it is for a 8BA then the standard duty truck flywheel is the one you want; standard with the 3spd tranny. Has 112 teeth and takes a 10 tooth drive gear which is the same as used with thr 9 1/2". There are also many out there with dual plate holes. The 11" is by itself.
