Flathead for sale
Discussion in 'Parts For Sale' started by 41LjH, Aug 3, 2019.
  1. 41LjH
    41LjH
    City: Winston Salem
    State: North Carolina
    Price: 8500 OBO
    Flathead Engine (49-53)
    Completely rebuilt with new parts.
    Engine block cleaned in electrolysis tank, re cleaned by the machine shop and crack checked.
    Bored 0.060 Rebuilder’s Choice 4 ring pistons (Egge pistons)
    Hastings rings.
    new cam bearings (Durabond)
    original cam regrown by Holman Moody (Isky 400 jr grind).
    stainless valves, reground seats, Johnson lifters, Isky springs
    connecting rods re-conned, new bearings (Clevite P.)
    Original 4” crank checked and turned. New crank bearings(Celvite P.) Center main blower strapped.
    Melling 19 oil pump.
    Best gasket set (copper head gaskets)
    EAC heads clearance d for valve lift.
    Original “truck” watepumps
    Flywheel resurfaced Starter rebuilt for higher torque,
    Currently this engine is set up for a 12 volt negative ground electrical system. Below are the 12 volt modifications.
    Mallory Unilite electronic distributor. Jim Lender AKA Bubba coil. New 8MM wires
    Fuel pump rod plugged. Set up for an electric fuel pump. Removing these items all allow the installation of 6 volt positive ground components an electric fuel pump for 6 volt operation.
    This engine is offered with a rebuilt Holley 2 barrel 3 bolt carburetor on a Ford 8RT intake.
    An aluminum four barrel intake and 500 CFM Edelbrock/Weber 1403 and/or an Edelbrock 3x2 intake with matching Holley 94 7RT carburators is available at an additional cost.
    I built this engine for my own use but I am unable to finish the project due to health. The engine is on a run in stand I made and has started. It holds 50-PSI but I have not run it long because there is no water in it.
    PM for details or call (336) 283 6070 and leave a message.
    I DO NO TEXT !!!
