Hot Rods Flathead Ford 6 cyl oil flow
Discussion in 'The Hokey Ass Message Board' started by Jack LeFore, Jul 12, 2015.
  1. Jack LeFore
    Jack LeFore
    Is there a oil flow restricting fitting in the oil flow system somewhere like the V8 ? Need to remote filter for space sake. Remove ing original filter canister. This is the 254 cu in M series 52-53 F6 truck motor(also industrial app motor). H series looks to be the same but 226 cu in. With remote installed, moments after motor starts, seems the valves start to rattle( get noise-y). 50 lbs oil pressure . Any Voices of experience out there? Thanks, Jack. ( coulda had a SBC, too easey! Not easey to be different and answer the ? , why)
