Technical Flathead Ford 8ba.stake loose lifter or?
Discussion in 'The Hokey Ass Message Board' started by wheeltramp brian, Feb 18, 2025.
  1. wheeltramp brian
    wheeltramp brian
    Got a customer's car here with an 8bA That was recently had some work done at h and h flatheads For a bad crank. They did the work and it turned out great. But after a couple 100 miles there was a ticking sound and it turns out number 3 exhaust had backed off. The
    Interference on the threads is almost non Existent. I adjusted it to the spec He calls for but don't want it to back off again.Should I Just stake the threads or add some type of lock tite. I've looked at other threads and there's no definitive answer. Or even anything recent within the last few years? I've emailed Mike at h and h, but he takes a while to get back to. 20250218_094007.jpg 20250218_092158.jpg What say you Flathead, people?
  2. Tim
    Tim
    from KCMO
    @mctim64 would probably have a thought
  3. tubman
    tubman
    Loc-tite has a product thar works by "wicking" and is for already assembled threads. I have had no experience with it, but it would seem obvious that if you're gonna try a thread locker, it would be the one.
  4. alchemy
    alchemy
    But would it work on oily threads? Seems to me that you’d have to disassemble to clean it before sealer. And if you’re gonna do that, you might as well just deform the threads a bit on the top of the lifter, and then no sealer needed.
  5. wheeltramp brian
    wheeltramp brian
    I watched the video about the loctite and it doesn't specify clean Or oily. I can pull the threads up more than needed and stake it a couple times to cause an interference fit and then adjust it down I think. And also use the lock tite
  6. tubman
    tubman
    I always like to try the least destructive message first. It's amazing the amount of progress that has been made in chemistry the last few years. One advantage of a flathead is that the cooling system doesn't need to be drained to pull the intake, which makes things a lot easier (and less messy).
  7. wheeltramp brian
    wheeltramp brian
    No, it's not a hard job but I just don't want to do it again. I can see that a couple others have been staked.
  8. wheeltramp brian
    wheeltramp brian
    I adjusted the lifter and rolled it over one revolution And it just pushes the adjustment screwed down as the threads are gone. If I could adjust it then somehow hold the valve and spring up then roll The lifter up And put a tack weld on it I think I would be good. Or I would have to pull the head and valve assembly to change the lifter.crap...
  9. drtrcrV-8
    drtrcrV-8
    It has been my experience that fixing it right, even if a bit more expensive up front, is almost always cheaper than doing a "band-aid "(also known as "half-assed") patch job, especially when it fails later & YOU get a reputation for doing THAT kind of work(& have to "eat" the cost of repair for YOUR patch job!) Your choice, just my opinion...
  10. wheeltramp brian
    wheeltramp brian
    You're correct about doing it right and half assed. As of right now I'm going to try and adjust it and put a tack weld on the lifter to prevent it from moving and the customer is okay with that. Should it happen again?He knows that the head and valve must be pulled in the lifter replaced
  11. wheeltramp brian
    wheeltramp brian
    I adjusted the lifter and put a couple tack Weld on it. It's nice and quiet and smooth. I checked all the rest and they seem nice and tight and to proper spec.
    seb fontana likes this.
  12. Kiwi 4d
    Kiwi 4d
    Are we allowed to know what brand works best. I can’t imagine there are too many options as to manufacturers. Seems a lot of vendors offer Johnson style lifters.
  13. CSPIDY
    CSPIDY
    I had one on my 8BA come loose last fall
    finally got around to repairing it
    Used brake wash repeatedly (with drain plug removed)
    Blew out with compressed air, then used heat to eliminate any flammable vapors.
    Tig welded the loose one, then used loctite thread locker 266 and primer on all the other lifters.
  14. wheeltramp brian
    wheeltramp brian
  15. tubman
    tubman
    I have a set of NOS stock 8BA lifters on the shelf for my next build.
  16. Onemansjunk
    Onemansjunk
    from Modesto,CA
    Excellent fix. Drive it or Look at it.
    leon bee likes this.
  17. dwollam
    dwollam
    I tried loctite, center punch on the threads etc multiple times. Gave up and put a couple zaps with the MIG welder and all was good. Been that way for many years now.
    Good to know I'm not the only one!
    Dave
  18. wheeltramp brian
    wheeltramp brian
    I figured someone had done it before.all the rest were nice and tight.wonder what happened to the threads on the one.
  19. I don't check in here as often as I used to, did you figure it out?
  20. wheeltramp brian
    wheeltramp brian
    I ended up welding it and it worked out. Mike from
    H and h never got back to me. Seems like the normal bad communication that everybody says. Need to find somebody else that specializes in flatheads That's closer by.
    Tim likes this.
