Technical flathead ford compression ratios??
Discussion in 'The Hokey Ass Message Board' started by 1930roadster, Dec 13, 2019.
  1. 1930roadster
    1930roadster
    Hi, so i'm ready to do my 8ba finally, but i have a concern... 8ba with a **** rotating ***embly balanced 3-5/16x4.25" with JE pistons, i already have 1115 edelbrock heads that i had show polished that has the 65cc chamber, i will be relieving the block so i know that will drop compression. I read the chart that Ryan posted about all this BUT here is what threw me off.... The sales guy said compression would be 10:1 with the 74cc heads! i found that hard to believe. I asked a few questions to see if he was a "sales guy" or a knowledgeable rep, my guess sales rep so i find myself here to see if anyone has been through this or purchased a kit from **** similar ... thanks
    Desoto291Hemi likes this.
  2. sunbeam
    sunbeam
  3. Bandit Billy
    Bandit Billy
    Detonation destroys flatheads and 10:1 compression sounds like trouble. Careful.
  4. tubman
    tubman
    Let's start again. You said you have a 3.125" bore. I don't believe this is what you meant, as it is 1/16" less than a stock 8BA. I don't think anyone would spend the extra money for a 1/2" stroker and then sleeve the bore undersize. What is the actual bore you are using?
  5. 1930roadster
    1930roadster
    3-5/16 bore... long week sorry
