Hot Rods flathead Ford crank pulley question
Discussion in 'The Hokey Ass Message Board' started by drumyn29, Aug 30, 2026.
  1. drumyn29
    drumyn29
    My guess is that the fan should be moved to the intake manifold instead of the crankshaft.
    Should I cut the fan mount off of the crank pulley or should I find an original pulley without the fan adapter?
    Screenshot 2026-08-30 at 2.22.22 PM.png Screenshot 2026-08-30 at 2.22.41 PM.png
  2. Ziggster
    Ziggster
    Never seen that configuration before. How was the belt run? I would get the correct pulley and fan ***embly to mount it to the intake.
  3. CSPIDY
    CSPIDY
    Is that a marine motor?
  4. drumyn29
    drumyn29
    tempImagejI3XdO.png tempImageb40kOj.png tempImagewV9kAH.png tempImageI6lvsv.png tempImagehCSxEN.png
  5. alchemy
    alchemy
    You can just trim the front stuff off, down to where the crank bolt sits. I’ve done it before.
    drumyn29 likes this.
  6. tubman
    tubman
    '39-'40 Fords had the crank mounted fan. It wasn't one of their better ideas and didn't last long. I wouldn't cut it up or anything like that. It may be a desired part for some, and you would be better off getting the proper part for the application.
    19Eddy30 likes this.
