Technical Flathead Ford Engine & Radiator Questions
Discussion in 'Traditional Hot Rods' started by mendo51, Dec 2, 2013.
  1. mendo51
    mendo51
    New guy with some basic questions:
    1. Has anyone put a flathead Ford into a non-ford car?
    2. If so, what have been some of the ways to desk with the radiator?
    3. What are your thoughts on the French Flathead? I have an opportunity to get one local to me.
    4. Does this qualify as traditional hit ridding...I hate to keep posting in the wrong place. New to the game.
    Thanks, E
  2. Mr48chev
    You might want to take a look at this. http://www.btc-bci.com/~billben/french.htm
    As in anything on the net you have to dissect it a bit and check other sources.
    What I am seeing is that you would have to do the same things you would do with a 49/50 or early 51 Mercury block with the early style bellhousing cast into the block.
    Radiator, you either have your radiator modified if it can be modified or you order a custom radiator to fit the application and engine.
    If you are thinking about putting a Ford flathead in the Hudson to me that is a waste as Hudson 308 flathead six with some performance mods is no slouch in it' own right. You had to have a pretty strong hopped up V8 Ford to keep up with one back in their day.
  3. hoggyrubber
    hoggyrubber
    i think there are a few members of the hudson modified club that have ford engines. also a mid 70's dodge van rad is close to a bolt in for a stepdown car. so to answer your first question though, no one has ever put a flathead ford engine in a non ford car. :D
  4. pasadenahotrod
    pasadenahotrod
    from Texas
    A fella in the Air Force stuck a hopped up V8-60 with a open drive 3-speed and a Halibrand in a Chevy Vega 30 years ago or so. And innumerable flatties were stuck in non-Ford chassis through the 20s-30s-40s-50s.
  5. DD COOPMAN
    DD COOPMAN
    Well, maybe not so fast! DD
  6. AMC360
    AMC360
    from Canada
    I am in the process of putting a flathead in a 36 Terraplane. For the rad, the stock one could not be modified so I am going with a custom one.
  7. dan c
    dan c
    i've heard that a few moons ago guys were putting flatheads in early mustangs and falcons!
    not exactly what i'd call a "sleeper."
  8. harleyjohn45
    harleyjohn45
    Over heating was the downfall on all the early flatties. I think the 49 and newer engines pretty much cured this problem. I drove a 53 ford for over 100k miles and it never overheated. My roadster has a 53 engine.
  9. Petejoe
    Petejoe
    from Zoar, Ohio
    Wives tales. Not at all the truth. Early engines will stay cool also.
  10. Rich Wright
    Rich Wright
    I have a '40/'41 99T in my sedan and it runs around 160...winter and summer. On a long grade it'll hit 180.
