Technical flathead ford exhaust flanges
Discussion in 'The Hokey Ass Message Board' started by theHIGHLANDER, Jan 9, 2016.
  1. theHIGHLANDER
    theHIGHLANDER
    I asked in my build thread several weeks back but didn't see an answer, and this may be so damn simple anyway. Is there a supplier for the exhaust flanges at the pipes? Not looking for the block flange for header fab (although my left front is really close), I need a couple 1 3/4 pipe flanges. Maybe I could trace something and with some sheet stock, a hole saw, drill, and band saw, build a couple, but that seems like a lot of screwing around for something so simple that may be commercially available. Any preferred suppliers/leads? If not, sheet stock it is. And I'm asking here because even in a simple google search I get everything EXCEPT what I'm trying to find. Thank you...
  2. Are you looking for the 2 bolt flange like the one in this photo?
    It's also the same flange I used for the block flange for primary pipe in this photo. 20150919_102235.jpg
    These flanges are 3/8" thick. I bought them at my exhaust warehouse for under $2.00 each. Most any good Exhaust shop also would have them hanging on the wall or could get them in a day for ya. You can also get them in 3 bolt pattern.
    The Wizzard
  3. Another suggestion is if you have a cnc plasma cutting shop in your area they may have the drawing and get them to cut it/them for you.
    Mtw fdu.
  4. theHIGHLANDER
    theHIGHLANDER
    Thanks for the heads up, PnB, yes that's what I need. Ready to fab my dual exh off the manifolds.
  5. walter
    walter
    Reds Headers sells just the flange
  6. kb cookout
    kb cookout
    Anyone selling them made from stainless steel ????
  7. Ole don
    Ole don
    Keep in mind, the front ones have 7/16 holes, the rear two are 3/8.
  8. Absolutely, go to S.P.D. Exhaust and click on flanges. I have bought lots of M.S. as well as S.S. from them. I can say,, nothing but High Quality. They make in house the very best U-Bends I've ever worked with. When doing Custom Exhaust for anything it's my Go To company. Grate people to deal with also.
    The Wizzard
