Flathead Ford HEAVY duty 3 speed??question??
Discussion in 'The Hokey Ass Message Board' started by overspray, Jul 8, 2008.
  1. overspray
    overspray
    CALLING Ford Flathead Tranny Gurus
    I bought this off the local swap-n-shop---was advertised as a 39 Ford 3 speed. I have an extra flathead that should run, so I thought I put this on instead of the old truck 4 speed it has now. The old guy (yes, much older than me) that had it, said it was behind a chevy 350 in a 39 Ford sedan he bought years ago. It had a speedway adapter, that was already sold, but the trans is really in nice shape. See how they shortened and bent the shifter (lowbuck hotrod style).
    Anyway, I found a little info on the web about it. It seems to be a heavy duty 3 speed for F1-F4 trucks from around 47-53 or so. Any old Ford tranny guys know what to use for the yoke at the rear or an adapter for a driveshaft yoke to make this work for a later 8 or 9 inch rear?
    overspray
  2. Your SURE that's a 3 speed...not a 4 speed???
  3. gas pumper
    gas pumper
    3 speed cause it has two rails.
    T-87 is a good trans.
    You need a slip joint in the driveshaft. usually do this at the front end. A driveshaft shop will hook you up.
    Frank
  4. JohnEvans
    JohnEvans
    from Phoenix AZ
    +1 for what gas pumper said. That will be a Spicer 1350 series joint.
  5. overspray
    overspray
    Thanks, guys.
    I forgot about those joints. I should be able to handle that with the local drive shaft shop.
    overspray
  6. mtflat
    mtflat
    I run a T87D in my 48 F1. 2nd and 3rd are synchro'd. The darn thing is bullet-proof. They were set up originally for open drivelines so you should be good to go. The advice you've already got is right on.
  7. NealinCA
    NealinCA
    My brother has one of those behind a 283 in his 41 Ford p/u. He's been abusing it for 30 years with out any problems. They are big, heavy and bullet-proof.
    Also, my dad's got one in his 46 p/u and plans to put one in his F-1.
    What you gonna use it in?
    Neal
  8. WOW! Never heard of a heavy duty 3 speed! Learn something everyday ;)
  9. overspray
    overspray
    Neal[/QUOTE]
    I have another flathead that was in a running truck when I drug it home. It came out of a 1950 Ford car. I'll stick it on that and then look at the 26 T front half touring I have sitting in the garage and ponder the possibilities. I have enough parts (front and rear axles and springs, double "z"ed frame, grille, F1 steering, windshield posts and frame, guide lights, 16 in wide whites on wires) to put a nice roller together, but I'm in the middle of another RPU project.
