Hot Rods Flathead Ford What Year ?
Discussion in 'The Hokey Ass Message Board' started by Jeff J, Apr 4, 2024.
  1. Jeff J
    Jeff J
    Ok, before ya slam me . Trying to figure out the year of this engine in my1932 . Been looking in the past files ,but more confused now than before ? By the header the paint is flaking off ! Scared the **** out of me as I just bought it and that was the first thing I looked at ! Casting numbers BO612 behind p***engers head on block. Thanks in advance! 32 pics 006.JPG
  2. Jeff J
    Jeff J
    I did find some casting numbers on the block on p***engers side behind the head rear BO612
  3. nosnhojguy
    nosnhojguy
    What happened above the rear header?
    Spooky likes this.
  4. xix32
    xix32
    `49 thru `53, with earlier heads
    Tow Truck Tom, Carter and Jeff J like this.
  5. BJR
    BJR
    that block looks trashed.
    Spooky likes this.
  6. Jeff J
    Jeff J
    Paint is flaking off ! As I just purchased it .
  7. gary macdonald
    gary macdonald
    49-53 with earlier heads ( 59ab )
    Tow Truck Tom likes this.
  8. Jeff J
    Jeff J
    In his notes said it had a Mercury Crank in it . As the gentleman that built this p***ed away . Out of New Smyrna Beach ,Florida as he was a pilot.
  9. caprockfabshop
    caprockfabshop
    Likely just bad paint prep on the block surface and the paint never properly adhered. Not a huge deal to fix, but best done outside the car.
    Jeff J likes this.
  10. alchemy
    alchemy
    The pic makes it look like a gaping crack. Like we are seeing into the coolant cavity.
    Desoto291Hemi and Jeff J like this.
  11. dwollam
    dwollam
    Same setup in my '40 Tudor. mine is a '52 block with offset ground Merc crank for 4.125" stroke and .125 overbore. '48 and earlier type Offenhauser heads, old Mallory dual poit dist.
    Dave
    Jeff J likes this.
  12. Jeff J
    Jeff J
    Paint flaking off! That was the first scary thing I saw before buying it ! Saw it in the pics too.
  13. Jeff J
    Jeff J
    So you can put earlier heads on a newer block . Sorry ,I'm new to the flatheads always been sbc . Thank You
  14. joel
    joel
    Yes! I have not done it, but there are lots of people who have. Do a search here and on the Fordbarn.
    " 59A heads on an 8ba"
  15. gary macdonald
    gary macdonald
    Yes , you need to block a p***age hole in the p***enger side front deck . I’ve got a 3.375 x4 1/8 merc crank , full floaters and 59 style heads . Its an old build that set for 20+ yrs . I’m sure a lot of them were done that way . Now I’d be hard pressed to bore a block that much , no matter the sonic testing wall thickness . I’d like to preserve as much as possible for the next caretaker .
  16. 19Fordy
    19Fordy
    Looks like it is a 1949-53 8BA or Merc block with early style heads, early Ford truck water pumps, Mallory distributor, 49-53 8RT truck oil pan and bellhousing.
    My 8BA with FENTON headers also had paint flaking that looked similar to yours. The exhaust heat was just too much for even the Bill Hirsch engine enamel. Do some probing with a screwdriver and check it out.
    Jeff J likes this.
  17. Jeff J
    Jeff J
    Car came out of New Smyrna Beach,Florida is the gentleman that built it Mr. G.Baker
  18. Jeff J
    Jeff J
    The paint is just flaking off . ThankYou. for info as what you said above has Ford truck water pumps and oil pan as stated in the build sheet but very limited on information as it has a c-4 trans on it
  19. clem
    clem
    If it doesn’t run hot, use any oil, lose any water, I would not be too concerned about it.
    (Could just be an adhesion problem with the paint).
    How about sharing some photos of the whole car ? - Thanks !
    Desoto291Hemi likes this.
