Hot Rods Flathead fuel pump problems
Discussion in 'The Hokey Ass Message Board' started by krylon32, Aug 9, 2022.
  1. krylon32
    krylon32
    from Nebraska
    Had a new FH motor built and a new 2 carb intake hardlined with pump, gauge and PCV. The intake uses 2 new 97's and a new Drake fuel pump. When the machine shop ran the engine on the test stand to break it in and tune it the fuel pump showed 2.5 lbs of pressure at idle. and 6 lbs at 2000 rpm. Pump should maintain a constant 2-3 lbs regardless of rpm. It's a new Drake pump. Intake builder says I need to change the spring under the diaphragm. There no way because of how the plumbing is done to run a regulator after the pump. Where do I find the appropriate springs and gasket set? First time I've tried a manual pump on my Flatheads.
  2. AVater
    AVater
    You can contact Charlie Schwendler on the Ford Barn. He rebuilds fuel pumps and has the components you want.
    alanp561 and Petejoe like this.
  3. krylon32
    krylon32
    from Nebraska
    Charlie received my pump on Friday, did the needed repairs over the weekend and sent it back today. Great service form a great guy.
  4. flatjack
    flatjack
    I just saw where Charlie has been banned on the Fordbarn. Total BS. Couldn't find a nicer guy.
    AVater likes this.
  5. AVater
    AVater
    Charlie was always helpful with my Ford and Mercury fuel issues as well as prompt and courteous with me.
  6. banjorear
    banjorear
    I've had three pumps done by Charlie. One was an early OHV Caddy high flow converted to flathead. All three produce 2.5-2.75 lbs no matter the RPM. Another vote for Charlie.
  7. krylon32
    krylon32
    from Nebraska
    My pump was a new Bob Drake Flathead pump that had been run about an hour. It needed a complete rebuild. Charlie said it was an accident waiting to happen. Should be fine now.
    Truckdoctor Andy and alanp561 like this.
  8. Davesblue50
    Davesblue50
    Charlie has been on Ford Barn forever. Never heard a bad thing about his work. What is going on there?
  9. Fortunateson
    Fortunateson
    Inquiring minds need to know...
  10. clem
    clem
    time to invite him to join the HAMB………
    Budget36 likes this.
  11. prpmmp
    prpmmp
    If any of you are okay with this:
    Quote:
    Let's square things away.....whether rural or urban in New York State all property tax
    rates are high, cops are ham strung because of 'progressive' woke law makers who
    gain office by pandering to where the voting 'blacks’' are. These same 'blocks' have invaded the sticks where I live. Friends have moved to Tenn. to get away...only to
    find the "blacks' steadily moving in there as well.
    Charlie ny
    Well… I guess I invite you to leave the forum as well. I will not allow, host, or even recognize racists on my sites. Period.
    Defending or accepting it is as bad as saying it. Disgraceful.
    __________________
    Ryan Cochran*
    - www.AtomicIndustry.com
  12. 51504bat
    51504bat
    Let's keep on task about fuel pumps and not go down a political rabbit hole. JMO
    warbird1 likes this.
  13. clem
    clem
    That puts a different slant on it.
    Sorry @Ryan , - nobody should have to deal with that type of thing.
    51504bat likes this.
