Technical Flathead guys, any info on this oddball block coolant manifold?
Discussion in 'The Hokey Ass Message Board' started by Russco, Jun 1, 2017.
  1. Russco
    Russco
    from Central IL
    My buddy has had this sitting in his garage for about 45 years. I recently sold it for him to a friend. I can't remember ever seeing this set up before. Does anyone know about this? He's always said it was out of a dirt track car and was to improve the cooling.
    Tatorboy likes this.
  2. $um Fun
    $um Fun
    from Nor Cal
    That's part of a Martas or similar style cooling system with a crank mounted water pump. They are more common on V8-60 engines.
  3. alchemy
    alchemy
    Didja notice the pan? I wonder what great stuff was inside that engine?
    loudbang, kidcampbell71 and patmanta like this.
  4. Russco
    Russco
    from Central IL
    I've never seen anything like this on a non V8 60. I looked at the front of the cam for any grind numbers, there were none. It doesn't have adjustable lifters either. The welds on the pan were very nice looking too. Looks like it was gas welded, I was hoping someone would have more info on the water manifolds too.
    kidcampbell71 likes this.
  5. tubman
    tubman
    Also the offset generator bracket as well. Multiple carbs!
  6. Russco
    Russco
    from Central IL
    So after cleaning all the acorns and junk out of the lifter valley it looks like it has keyed hollow lifters in it! I bet it's got some fancy shmancy radius lifter cam in it. Pretty cool!
  7. gimpyshotrods
    gimpyshotrods
    Man, I hope that turns up all usable!
  8. woodbutcher
    woodbutcher
    :D Ain`t it amazing what can be found inside old retired engines?
    Good luck.Have fun.Be safe.
    Leo
  9. V8 Bob
    V8 Bob
    The first time I saw a that type of cooling system was back in the late '80s while working out of Bill Stroppe's shop. Bill was restoring one of his old flathead powered race car, (I think a Kurtis) and said many circle track flatheads used these systems.
  10. bowie
    bowie
    The go to radius lifter cam back then was Isky's 404A grind, billed as "constant acceleration " model. Hopefully that's what it is. They are stamped as such, though. A very interesting mill , you've got there!
    loudbang and Squablow like this.
  11. Tatorboy
    Tatorboy
    This is from Roger Huntingtons 1951 book How to hop up Ford & Mercury V8 engines. (Originally posted by Bob Clark on the Flatspot)
  12. Tatorboy
    Tatorboy
    IMG_0931.JPG Decided to take a look at the cam. Isky 404A Will post more when I take the heads and pan off.
    bowie, loudbang, Russco and 1 other person like this.
  13. Russco
    Russco
    from Central IL
    I must not have looked close enough I sure didn't see that on the cam when I looked (although I don't honk I had my cheaters on at the time either) keep me posted what you find when you get it apart.
  14. tubman
    tubman
    I don't know what dirt track cl*** that engine ran in initially, but I'll bet there was some cheating going on!:eek: 404A and "stock" iron heads?
  15. Tatorboy
    Tatorboy
    They would weld metal biscuits inside stock heads to increase compression. Timing cover and gear had to be removed to see the cam markings.
    bowie likes this.
