Technical FLATHEAD GUYS- cracked pan rail Fixable?
Discussion in 'Traditional Hot Rods' started by Mr.Musico, Mar 3, 2014.
  1. Mr.Musico
    Mr.Musico
    from SoCal
    Had water in exhaust and in the pan but didnt appear to be any in the cylinder, dropped the pan today and found this. Fixable? If so any recommendations in the OC or LA area you remmomend?
  2. pasadenahotrod
    pasadenahotrod
    from Texas
    Always a death sentence in my experience.
  3. prpmmp
    prpmmp
  4. thirtytwo
    thirtytwo
    If it was just a leaker it could probably be patched but my concern would be the crack going through the main web
  5. ROADSTER1927
    ROADSTER1927
    Going into the main bearing web I would say NO.
  6. tommy
    tommy
    Uncracked blocks can still be found. I would not spend money on a cracked block. JMHO
  7. choppedtudor
    choppedtudor
    bolt it to the end of a chain and sell it to a guy with a boat....
  8. temper_mental
    temper_mental
    from Texas
  9. tubman
    tubman
    I second checking the FORD BARN thread before making a final decision.
  10. Andy
    Andy
    If it has water out the exhaust it is probably done. I would JB or something to patch it enough for a pressure test.
  11. Mr.Musico
    Mr.Musico
    from SoCal
    Kinda what I was thinking
  12. 1949*john
    1949*john
    if you cobble some jb weld on it and it stops the leak ask your self !
    now do I really dare to take it anywhere and ruin the crank , cam and so on .
    like the guy said - sell it to a guy with a boat and save you some headaches .
    BUT THATS JUST MY THOUGHTS .
  13. Mr.Musico
    Mr.Musico
    from SoCal
    no I wouldnt think of doing that< i agreed with the comment to the extent that the crack is deep and the block may be too far gone....
  14. dtracy
    dtracy
    There are other cracks because that crack in the pan rail does not leak water. Look above it where the water jacket is. The main bearing web is probably cracked into the water jacket there, or around the bottom of the cylinder.
    Dave.
  15. flat286
    flat286
    from Indiana
    Yep .That's the bad part .what usually cracks that cracks something else. Not good.Makes you say all kinds of four letter words..And in this day and age hard on the wallet..
  16. Jimmy2car
    Jimmy2car
    from No. Cal
    I just went thru the exercise of finding a new block. Yours looks done to me. Even if you can stop the water leaks, I sure wouldn't trust it at all. You're in Socal, so go to H&H and beg a good deal on another block that's magged, pressure tested and sonic checked. It'll be money well spent.
    Good luck
