Flathead guys, has anyone used this cam.....?
Discussion in 'The Hokey Ass Message Board' started by rat bastad, Dec 13, 2012.
  1. Im looking at having Cam Techniques grind this stick up on my core.
    F 335-13
    Lift int & exh .335
    Advertised duration 270 int & exh
    Duration @ .050 228 int & exh
    Lobe separation 113
    Mild 37 221, stock ports, shaved heads, no relief, headers, dual 2" exhaust with Smithys, hot ign, PM7 x 2 97s in a stripped down Deuce roadster with 3.54's.
    Don't want to overcam this engine but would like a nicer note and and little bit more kick - esp with the shaved heads and dual carbs and hot ignition.
    Any input would be much appreciated !
  2. dan c
    dan c
    if those specs are right you should have no problem with that cam--it looks to be milder than the isky max 1 and a little more than the isky77. and you should be ok with the heads.
  3. bcowanwheels
    bcowanwheels
    Hard to beat the isky 400 jr in a flatty, been the standard for decades
