Technical Flathead guys - what for temp gauges?
Discussion in 'Traditional Hot Rods' started by cederholm, Sep 14, 2019.
  1. cederholm
    cederholm
    What setups are you guys using to monitor your engine temp? I have the original senders on my 1952 8BA, but I don't have the gauges. Were there any SW gauges that will work with the stock Ford senders or are you guys using modern senders with an adaptor? And if the latter, two senders and two gauges?
    So, what'cha running?
    Thanks,
    Carl
  2. klawockvet
    klawockvet
    I used two SW senders and two gauges.
  3. tubman
    tubman
    I am running the stock sender on the right head with the stock gauge and an aftermarket mechanical gauge mounted under the dash on my '51. Kinda a "belt and suspenders" approach. I know the different sides are mostly independent, but this still gives some sense of security.
    cederholm likes this.
  4. 37_Ford
    37_Ford
    from Illinois
    I am using a newer electric Stewart Warner one wire gauge with a sender in each head. I connected the senders to an A-B toggle switch under the dash so I can switch to check both sides.
    Atwater Mike, cederholm and doinbad like this.
  5. 51504bat
    51504bat
    Running 2 electric VDO gauges and senders that go to 220. All the other gauges I found went to 280 degrees so when I was running at 170-185 the gauge needle was just registering. With the VDO gauges the needle is in the middle of the gauge at operating temperature. gauge 1.jpg
  6. init1
    init1
    I found a nice large size SW mechanical
    Guage. A proper guage for a 50's old style
    Hot rod.
    Sent from my SM-J727V using The H.A.M.B. mobile app
  7. hfh
    hfh
    from Western MA
    IMG_2691.JPG I'm using this nice old gauge in my roadster. Thinking of adding another one for the other side.
  8. Old-Soul
    Old-Soul
    On my '49 the stock gauge would never read right (at proper operating temp it'd be pegged as if it were over heating). Problem remained even with a new sender.
    I got a NOS Stewart Warner mechanical and installed it with an under dash bracket and away we go.
  9. tubman
    tubman
    Both gauges (one stock, one mechanical add-on) read about the same on my '51. The only difference I have seen is that the stock gauge seems to respond faster. When the stock gauge hits 180, the mechanical is at 160. A couple of minutes later, they are both at 180. Funny, I thought it would be the other way around.
  10. lodaddyo
    lodaddyo
    Temp gauges ill be running in my roadster. One for each head. 2 5/8 Stewart Warners with new capillary tubes installed
  11. PHIL COOPY
    PHIL COOPY
    I put a bung in the radiator tank and just run a modern electric gauge.....
    Phil
  12. clem
    clem
    On my 8ba after years of one gauge, I changed to one in each head, the adapters cost more than the gauges !
  13. Dirty Dug
    Dirty Dug
    Stewart Warner mechanical in the cars I've built.
  14. roseville carl
    roseville carl
    two senders one gauge and a spdt switch
    Hotrodmyk, cederholm and 48fordnut like this.
  15. Flathead Dave
    Flathead Dave
    from So. Cal.
    Use two mechanical gauges. Any brand will do.
  16. Chappy444
    Chappy444
    I have a guage that is two temp gauges in one. Two senders, one gauge
    Chappy
  17. cederholm
    cederholm
    Awesome advice all - greatly appreciated.
  18. I have an Autometer gauge in my cab that monitors the p***enger side. I have a Mooneyes direct mount on the drivers side that I put there mostly for show. If one side is significantly hotter than the other one, you've got bigger problems
  19. alchemy
    alchemy
    I've got a late '40's Stewart Warner in mine. It only covers the left bank, but I've got room on the other side of the dash and have thought about adding another to the right side.
    kadillackid likes this.
  20. clem
    clem
    Just on a side note, something I did:
    If you put in two, test them in boiling water together, and take note of if they read the same and ‘climb’ at the same rate, otherwise you may forever be thinking that one is reading wrong or differently from the other.
    A 2 B, Atwater Mike and kadillackid like this.
