Projects Flathead head studs
Discussion in 'Traditional Hot Rods' started by GMC28, Dec 4, 2017.
  1. GMC28
    GMC28
    from New York
    I’m using a newer 49-53 block, but I want to use a set of the pre 49 heads with the center water port. I want to order a set of studs, but there are two different sets for pre 49 and 49-53. I’m not sure which set to order. Thanks
  2. flat 39
    flat 39
    Order the studs for the heads that you will be using. Most aftermarket aluminum heads use longer studs.
  3. alchemy
    alchemy
    Yep, the length is the only difference. And most aftermarket heads have a consistent length to all the studs (not shorter on the bottom rows), so ask the vendor which set has the correct length for you.
  4. sloppy jalopies
    sloppy jalopies
    memory says there are 2 odd length bolts each side on an 8BA...
  5. joel
    joel
    Check fordbolts.com. They have correct studs
    cadillacoffin likes this.
  6. dwollam, biggeorge and cadillacoffin like this.
