Technical Flathead head swap?
Discussion in 'Traditional Hot Rods' started by GMC28, Aug 13, 2017.
  1. GMC28
    GMC28
    from New York
    I'm building a flathead motor, and was told by a couple guys that I can use the older style head with the center cooling outlet on a 49-53 block. You just need to block off an extra water p***age that is near the front of the block. Does anyone know if this can be done, and possibly give me more specific information on exactly what's involved? I like the look of the older style head, and would like to use them if possible. Thanks, Ed
  2. Fortunateson
    Fortunateson
    I need that info as well. What about changing the intake to the earlier style?
  3. 19Fordy
    19Fordy
    I did it years ago. Here's how. If you Google" How to install early heads on a ford 8BA" and other info. appears. You use the early head gaskets.
    http://www.wilcap.com/59A heads 8BA block.pdf
    You may have to raise your carb. with a spacer depending on the carb you are using and your throttle linkage set up. This used a 1 inch spacer.
    LOU WELLS likes this.
  4. sloppy jalopies
    sloppy jalopies
    did that...
    you will need to plug a .300"ish hole under the right head, near where the distributor ty- down is located... I used br*** rod... and i froze it over night for an easier installation the next morning...
    I stuffed a small rag in the hole, reamed not drilled it to the br*** rod's size...
    then vacuumed it out [twice], finally pulled the rag out with tweezers... vacuumed again...
    IMO... there are a bunch more 59 AB head designs than the 8BAs...
    used to buy 'em at Staford for $100 a pair, those were the days...
    also don't polish the early aluminum intakes as they have some hot air p***ages just under the surface... paid for the polishing... used [4] intakes... nope... paint it...
  5. flatjack
    flatjack
    Just use the right size cup plug.
  6. 19Fordy
    19Fordy
    Be sure to install the distributor at the same height
    above the "deck" as before so as to get proper gear teeth mesh.
    I used a 1/4 inch spacer and a 1/4-20 socket head cap screw.
    No set screw as I didn't want it to fall into the opening by mistake.
  7. GMC28
    GMC28
    from New York
    Exactly what I was looking for. Thanks guys
  8. 41fastback
    41fastback
    I used hex socket pipe plugs flush with the block. One is under the head and one showing. '51 Merc. Also has crab distr.
  9. 19Fordy
    19Fordy
    I also used socket head pipe plugs plus JB WELD as sealant..
    No leaks after many years.
