Hot Rods Flathead head swap
Discussion in 'The Hokey Ass Message Board' started by jscott1, Mar 4, 2018.
  1. jscott1
    jscott1
    Putting 59ab heads on an 8ba block. Is there any reason other than appearance? Do they cool better?
    Reason is I have a 8ba and a set of finned 59ab heads.
    Jim
  2. RICK R 44
    RICK R 44
    You will have to plug a couple of water p***ages in the block to run the early heads
    jscott1 likes this.
  3. big duece
    big duece
    from kansas
    There is a steam hole(s) on the 8ba block that will have to be filled. I personally like the looks of the 59a heads, but I believe the moved the thermostat forward on the 8ba for air bubbles less likely to be trapped and keeping temps down.
    jscott1 likes this.
  4. jscott1
    jscott1
    I knew about the plugs. I just wondered if other than appearance if there was anything to gain in the way of performance or cooling.
  5. alchemy
    alchemy
    Actually you will probably hurt cooling performance. Ford enlarged the water jacket holes at the back of the block (and the heads to match), and if you put small holed early heads on the larger holed late block you will be slowing the flow. Henry must have wanted the bigger holes for a good reason.
    jscott1 likes this.
