Flathead heater hose flow?
Discussion in 'The Hokey Ass Message Board' started by Kevin Lee, Jan 12, 2011.
  1. Kevin Lee
    Kevin Lee
    Super Moderator
    Overall coolant flows: Out of the bottom radiator tank, into the bottom of the engine through pumps, through the block and out the heads and upper hoses to the top tank, then back through.
    So which way does coolant flow through the heater hoses? Looking at the layout I could make an argument for either direction. Not willing to unhook a hose and start the engine just yet.
  2. T_Bird Guy
    T_Bird Guy
    On my 1947 Ford one hose is tapped into the lower radiator hose and the other hose is into the head.
  3. Kevin Lee
    Kevin Lee
    Super Moderator
    So, I think that further complicates it. Which way would you think it flows then?
  4. T_Bird Guy
    T_Bird Guy
    I believe it flows out of the head into the heater core. I have a shut off valve mounted in the head before the heater hose. The return hose must be the one that goes into the lower radiator hose.
  5. oldrelics
    oldrelics
    from Calgary
    x 2
  6. fab32
    fab32
    X3, Both the radiator and the heater excange heat to the outside so it would be logical for any cooled water to reenter the system at the bottom of the radiator/engine combination.
    Frank
  7. REM/Mo
    REM/Mo
    from Missouri
    X3
    The pump is causing suction on the lower hose and pressure in the block which causes the flow through the heater..
    The water coming out of the head is hotter and that is what you want going into the heater. Not the water that has already been cooled by the radiator.
  8. 50 Ford 1963
    50 Ford 1963
    Yep, that is correct, and the heater doesn't do quite as good of a job as the radiator does cooling the water back down. When I am using the heat in my car my right side runs a few degrees hotter than the left side.
