Flathead help. ID??
Discussion in 'The Hokey Ass Message Board' started by Killer, May 8, 2004.
  1. Killer
    Killer
    Got this 59 the other day. It was inna guys shed for awhile. I hosed it off last night to have a look...
    I dunno what I have.
    Timing cover:
    It has adj. lifters:
    The bottom end:
    Rods are marked "99":
    Shouldn't there be a cleanout hole through the rod journals??:
    Other than these pics, all I know is it's bored 60 over.
    Any help is appreciated.
  2. NoSurf
    NoSurf
    I would try looking at the VanPelt Sales flathead page:
    flatty
  3. side_valve
    side_valve
    Alliance Vendor
    Looks like a '47 block to me
  4. Mr 42
    Mr 42
    from Sweden
    Maybe this can help you.
  5. Randy D
    Randy D
    No additional help with the I.D. That one looks exceptionally clean inside. Was it like this when you got it? I know you said you hosed it off, but damn, all the ones i have seen inside are heavily sludged.
  6. Digger_Dave
    Digger_Dave
    The lack of cleanout plugs means that crank
    uses "full floating" bearings (only two rod bearings per rod journal)
    The water pump pullies are custom made.
    New distributor cover and you might just have a "keeper!"
  7. Killer
    Killer
    Thanks for the article, that's a keeper!
    Anyone know what the 99 on the rods mean??????
    The bearings are full floating, I pulled a rod cap.
    Why would it need a new timing cover??? Don't like old chrome?!?!!! I think the pullys need to go!
    yes it was that clean... just covered in dust.
  8. Digger_Dave
    Digger_Dave
    [ QUOTE ]
    [/ QUOTE ]
    The first picture looks like a piece of the timing cover is missing. (the picture isn't Hi Res by the time it gets posted)
  9. I have no idea what I'm talkiking about but tonite when I was reading the Bishop/Tardell chapter on flatmotors I think I remeber seeing something about 99 truck blocks?
  10. Iceberg
    Iceberg
    My 1945 truck had a Model 99T (239 cid) flathead in it. I believe that the 99 would be for '41 - '45 engines.
  11. Digger_Dave
    Digger_Dave
    [ QUOTE ]
    [/ QUOTE ]
    The "99" series engines according to Vern Tardell are a bit "tougher" than the regular engines. (thicker walls) He is always on the search for these engines to run in his Bonneville racer.
  12. Bruce Lancaster
    Bruce Lancaster
    "99" is the prefix number for 1939 introduced 3 3/16 bore flathead, used in Merc and big trucks, rods used with that number 1939-41. The block with 59 was used 1946-48 on all Ford lines. The 99 rods are virtually identical to the 29A rods used originally on this--they're just a substitution made by a rebuilder. You have a nice pile of stuff there.
  13. Kevin Lee
    Kevin Lee
    Super Moderator
    Nice score with the adjustable lifters. I actually LIKE those pulleys from what I can see. Interested at all in getting rid of them?
  14. Digger_Dave
    Digger_Dave
  15. Killer
    Killer
    Thanks again for the info guys.
    Here's another pic for ya:
  16. no freekin way an old skool iskederian cam
  17. Steve
    Steve
    damn guess its kinda easy to identify that cam. that timing plate and distributor looks like its either the crab style think that was used 42 to 46
