Flathead help
Discussion in 'The Hokey Ass Message Board' started by EnglishBob, Sep 13, 2010.
  1. EnglishBob
    EnglishBob
    Gents,
    I just did a flatty swap and crawling around under the car afterwards found a ball bearing about 1/8th diameter.
    Haven't got a clue what it's from or even if it's from the swap.
    Any ideas?
    Thanks
    Bob
  2. 8-Track
    8-Track
    Water Pump ?
  3. EnglishBob
    EnglishBob
    never took the water pumps off or apart.
  4. mtflat
    mtflat
    I can't think of a ball-bearing in a flathead. You should be ok
  5. EnglishBob
    EnglishBob
    Could it be from a sender,the transmission(speedo drive?).
  6. Teep
    Teep
    from Travis AFB
    your pilot bearing in your flywheel? if u have a bearing and not a bushing. there arent many ball bearings.....
  7. seb fontana
    seb fontana
    from ct
    your wife tossed it there to wind you up..?
  8. R Pope
    R Pope
    Just a single 1/8" ball? Were you working on a carburetor?
  9. crash11049
    crash11049
    could it come frome inside a greese fitting? could have sheared one off the suspension when putting in motor?
