flathead intake manifolds- Identifyiing?
Discussion in 'The Hokey Ass Message Board' started by kidwired, Nov 28, 2004.
  1. kidwired
    kidwired
    from Sonoma CA
    What are the visible differences between the 38-48 (what I need) and the later intakes?
    Someone help me out so's I dont end up with the wrong one [​IMG]
  2. AV8 Dave
    AV8 Dave
    Hi kidwired! Easy stuff! Look on the left side forward and if there are two holes (or one hole and a large diameter "angled out to the side" oil filler tube) it's a later manifold. The forward hole is for road draft tube which the earlier engines didn't have. [​IMG] Regards, Dave.
  3. tommy
    tommy
    both of the single 4 bbl manifolds at the top of this page are the later 1ntakes even though the oil fill and road draft tube holes are in different locations. The earlier manifold won't have these as Dave said.
  4. If you buy the later intake there is a plug that can be used to block of the road draft tube. HRP
  5. flatoz
    flatoz
    you can use the later intakes , as people have said , just block off the holes and your in business. I used welch ( freeze) plugs just go to your local parts store and get some that fit and a little silicon and your in business.
  6. Automotive Stud
    Automotive Stud
    I don't know if this is true for aftermarket intakes, but I've heard that the later ones hold the carbs at a different angle. I don't know if it would make a difference, though.
  7. Bruce Lancaster
    Bruce Lancaster
    Early has carb pad at an angle to engine, late is parallel. Carbs are level in stock installation in both, engine mount angle is different between generations.
