Technical flathead intake manifolds
Discussion in 'Traditional Hot Rods' started by trvguy, Sep 8, 2013.
  1. trvguy
    trvguy
    can a ford 49 thru 53 intake manifold be used on a 48 merc engine?
    thanks for any help.
  2. Bruce Lancaster
    Bruce Lancaster
    Yes. Use the '48 fuel pump mount and pushrod, plug hole for road draft or use it to build a PCV setup.
  3. 40FordGuy
    40FordGuy
    Yes; All the Ford intake ports are the same.
    However, if you want to use the 48 and earlier (58A) intake on a 49 / 53 (8BA) block, you have to remove (or shorten) the crankcase vent tube, which is located at the right (pass side) front corner of the lifter gallery. The early intakes will not clear the top of the vent tube.
    Happy Flatheadin' 4TTRUK
