Technical Flathead interchangeability
Discussion in 'The Hokey Ass Message Board' started by draggin49, Oct 17, 2022.
  1. draggin49
    draggin49
    Have a 1932 Ford that is currently running an 8ba motor. It has a trans adaptor that makes a gm manual trans work with the 8ba.
    The 8ba motor needs replacing /rebuilding . But I do have a rebuilt 21 stud motor . My question is how many things would I need to change in order to make the 21 stud motor work in place of where the existing 8ba was ? Would motor mounts have to be relocated /changed ?Different trans adapter ? I will likely have another 8ba built but shop won’t be able to get that done for 4-6 months cuz they are really busy . So I figured maybe the 21 stud could get me back on the road till the other motor is done and ready
  2. Petejoe
    Petejoe
    from Zoar, Ohio
    What year block is your 21 stud?
    35-36 and 37 engines have a different front mount configuration.
    You most likely would not be happy with the smaller engine. There is a considerable difference in power. 8ba’s run much smoother.
    Id suggest selling the small rebuilt 21 stud engine and finding a good used 8ba in the mean time since you intend to just change it out after your 8ba is rebuilt.
  3. Petejoe
    Petejoe
    from Zoar, Ohio
  4. Budget36
    Budget36
    I’ve only had a few FH V8’s, but never an 8ba. I’d ***ume (surely don’t know) the FH trans would be the same circular bolt pattern for an 8ba and say a 59a with the integral bell housing casted with the block. Definitely mock it up first. The 221 (I put one on a ‘42 Ford PU) moved the truck just fine, but was all flatland driving and local highways/town driving.
  5. alchemy
    alchemy
    Your clutch is going to be more problems than it’s worth. The late flywheel probably has a larger clutch on it to fit the GM trans. That won’t work on the early 21 flywheel. And you can’t put the late flywheel on the early engine.
    I’d do as suggested and look for a used 8BA to drop in temporarily.
    Desoto291Hemi, draggin49 and Petejoe like this.
  6. RICH B
    RICH B
    Pretend it's '55 and drop in a 265.
    Acme45 and A Boner like this.
  7. A Boner
    A Boner
    FoMoCo…interchangeability…what is that, said FoMoCo head engineer!
  8. draggin49
    draggin49
    Thanks guys , my gut feeling was there would be a few things that wouldn’t be the same . I will search out another 8ba to keep the swap as simple as possible
  9. flathead4d
    flathead4d
    Check out the ford barn.com every question you have can be answered there.
