Technical Flathead machine shop in Northeast Ohio
Discussion in 'The Hokey Ass Message Board' started by Grumpy Old Mechanic, Feb 15, 2022.
  1. I have a 59A flatty at a machine shop for over a month now and there has been no movement. Does anyone have a good shop within driving distance of Northeast Ohio? First need is to hot tank block and magnaflux then pressure test, if the block is good I will need to resurface heads, intake and maybe bore out cylinders to .04
  2. Just Gary
    Just Gary
    Welcome to the HAMB.:)
    Despite growing up in Geneva, I don't know any vintage engine builders in NE OH, so all I can do is bump your request back up to the top.
  3. kb cookout
    kb cookout
  4. Bert Kollar
    Bert Kollar
    Metals Crankshaft Cleveland since 1947 if still open, great work. 216 431 5778
    Just Gary likes this.
  5. Petejoe
    Petejoe
    from Zoar, Ohio
  6. two couped up
    two couped up
    from pa.
    If you find a shop that is not loaded with work at this time of the year avoid them, the machine work may not be up to par. My 59A block has been at the shop for over 2 months, and there are still several blocks ahead of mine. Another thing is to ask them if they have the plates to pressure test the block, most shops can't pressure test a flathead, and don't let them tell you if it p***ed the mag it will be good, been there done that, a mag test does not pickup porosity, so a pressure test is a must.
  7. Thank you everyone, some places to check out and great advise.
  8. ClayMart
    ClayMart
    There's a lot of guys on this site that are full of it. And by "it" I mean great advice, of course.
    :rolleyes:
    Welcome aboard and hang on tight!
  9. sfowler
    sfowler
    I HAVE USED -- STORY MOTORS -- IN M***ILLON OHIO SEVERAL TIMES . FLATHEADS AND EARLY OLDS 303 . ALWAYS HONEST WORK 330 / 837 2049
    Petejoe likes this.
