Technical Flathead main bearings
Discussion in 'The Hokey Ass Message Board' started by keith27T, Apr 18, 2018.
  1. keith27T
    keith27T
    A while back I had a merc crank ground and at the time I bought bearings for the mains.. My question is will these bearings fit an 48 and earlier block? Are they the same? As for an 8ba?
  2. Bruce Lancaster
    Bruce Lancaster
    For '39-48 block with Merc crank you need 8BA mains. The rear one is a bit different on the crank side. The good floater rod bearings will be good to go on the Merc crank.
    (edit...both type rear mains will fit either block, BUT the rear main bearing surface on late crank is slightly shorter than 59A...and fits the late bearing, of course.)
  3. keith27T
    keith27T
    Thanks Bruce
  4. Mac VP
    Mac VP
    Front and center main bearings are the same from 1939 through 1953. The rear main bearing is different. You can see the difference by the width of the locking tang (the part of the bearing shell that fits into a notch machined into the block).
    stillrunners likes this.
  5. keith27T
    keith27T
    Can I use the 8ba rear with the merc crank?
  6. Mac VP
    Mac VP
    Match the main bearings to the block. In other words, any 49-53 flathead block should be fitted with the 8BA type main bearings. The 39-48 blocks would get the corresponding main bearings (which have the 81A prefix on the factory part number).
    You can install the 49-53 Mercury crankshaft into the 39-48 block, but as stated above, you will have to use the 39-48 main bearings. It’s generally recommended that you should use the 8BA type rods along with the 49-53 Mercury crankshaft (and the 8BA type rod bearings).
    deucemac likes this.
  7. keith27T
    keith27T
    Where can I get 50 over mains for a 39 to 40 block?
  8. keith27T
    keith27T
    I have them for the later 49 and up block
  9. Flatheadjohn47
    Flatheadjohn47
    from Lewes, DE
    Maybe Baxter Ford in Kansas.
  10. keith27T
    keith27T
    Thanks
    Email sent
  11. Ritzy1
    Ritzy1
    Mac, hopefully I've made the right decision to go with full floating rod bearings for my motor with this same combination ('48 Ford 59AB motor/4" Merc crank). I had read where those bearings were superior to later versions.
  12. alchemy
    alchemy
    Full floater bearings were even installed in engines that didn't originally come with them, for performance purposes. I've read of race hemi engines having full floaters used. No idea what they found those bearings from though.
    I do know it takes much more care to correctly clearance and ***emble full floater bearings than just snapping in some tanged insert bearings. Take your time.
  13. Bruce Lancaster
    Bruce Lancaster
    floaters were used in about all flathead race motors. Early OHV's were rod ******s once they were souped up and turned too fast, So Moon offered floater kits to eliminate one of the main problems that destroy rods at high RPM.
    From what I have found out so far ( a rather poor HRM article and oldish Moon catalogs) they used Ford stuff if dimensions of engine were in range with lots of machine work, and Moon supplied larger floater bearings that I ***ume were special made. They noted Packard, Chrysler, and others in the catalog on the big ones.
    AND...to use '49 up crank in '39-48, you will need '49-53 main bearing.
    Block fit is the same, but late crank has a shorter space on the bearing area and thicker cheeks on the bearing take up the slack.
    keith27T likes this.
  14. keith27T
    keith27T
    Thanks again Bruce
  15. keith27T
    keith27T
    Also have a 1CM cam. Would this work in the earlier block? Timing gear? Any modifications needed.
  16. Bruce Lancaster
    Bruce Lancaster
    It will fit but you'll have to figure out a good ignition to fit the late front cover. Normal gearing is the late type with this but there are builders that prefer thrust against the block on all. Mercury used the early gears for a while and then switched to the late gear on later '49's!
  17. Bruce Lancaster
    Bruce Lancaster
    Also...remember that the engine will be significantly shorter with early cam and water pumps, '42 distributor if you are putting this into an early car.
  18. keith27T
    keith27T
    Would like to use the dual point two bolt crab style?
  19. keith27T
    keith27T
    Another cam I have is marked 59 so aguess will use it with the crab distributor
  20. ROY Patrice
    ROY Patrice
    from FRANCE
    Hi Bruce
    First excuse my english i'm french, i hope you can help me
    I have a French flathead (39 / 48 specs) and I want to put a **** crankshaft (49 up crank).
    To put 49-53 main bearing i need to machine to reduce the thickness of the block of arround 0.0287 inch
    does that seem normal to you
    Thanks
  21. 41fastback
    41fastback
    Bruce p***ed away a few years ago. We miss him.
  22. Hello Roy ,
    I think Bruce posted that the block dimension was the same,,,it’s the crank that is somewhat different .
    Use 49-53 bearings for a 49-53 crank,,,,no matter on the block .
    The French blocks should be the same 39-48 specs,,,,as the Ford original spec .
    Good luck,,,,,it should run great .
    Tommy
  23. ROY Patrice
    ROY Patrice
    from FRANCE
    desolate of my clumsiness
    Desoto291Hemi likes this.
