Technical Flathead merc crank plug question
Discussion in 'The Hokey Ass Message Board' started by lodaddyo, Apr 23, 2016.
  1. lodaddyo
    lodaddyo
    Pulled the welch plugs out my merc craank and tapped holes for threaded plugs. Cant seem to tap the hole enough to get the plugs flush. Would this be an issue? ImageUploadedByH.A.M.B.1461430690.637778.jpg
  2. Bader2
    Bader2
    Did you use a bottoming tap?
  3. lodaddyo
    lodaddyo
    3/8 npt pipe tap
  4. 51 MERC-CT
    51 MERC-CT
    It probably will not make any difference but if you want to go closer to flush, cut the tap shorter with appropriate sharpening. Then you can go deeper. I have done it more than once.
  5. Petejoe
    Petejoe
    from Zoar, Ohio
  6. hot rust
    hot rust
    i'd be more worried about the balance if you not going to have it balanced than i would the plug sticking out.
  7. lodaddyo
    lodaddyo
    Thanks for the help. Block and crank going to the machine shop monday. It will all be balanced
  8. deathrowdave
    deathrowdave
    from NKy
    Near dead center of the crank balance will not be an issue
