Flathead not starting. WHY?
Discussion in 'The Hokey Ass Message Board' started by sociallydistorted, Nov 26, 2007.
  1. sociallydistorted
    sociallydistorted
    I got a little boozed up last night over at a buddies house and when I got ready to leave, I get in the car, turn the key, push the starter ****on and nothing. Actually it clicks one time and one time it made a winding noise but thats it. Battery is good. Electric fuel pump is working. The engine is a '49 Merc flathead. I've never owned or worked on a flathead before. I didn't even attempt to diagnose the problem last night as I was too drunk. I'm going over after work tonight to see what the problem is. Just wanted some opinions before I take a look. Thanks
  2. 53sled
    53sled
    from KCMO
    let me know before you drive next time, so
    I can park it and wait for you. Drunk driving is not cool.
    That was an angel on your shoulder.
    Its a bad ground, corroded cable or both.
  3. sociallydistorted
    sociallydistorted
    I was only driving it about 10 feet away so my DD could get me home. I was parked in front of him. Hahaha.
    I was thinking the same thing with the ground or cable but like I said, I'm no flathead expert so I didn't know what was going on. Thanks 53.
  4. pasadenahotrod
    pasadenahotrod
    from Texas
    Always use at least one extra ground cable or strap between engine and ch***is and body. Make sure the contact points are free of paint, use a good star washer and ground problems will be a thing of the past (dim lights, poor or slow starts, etc.).
    Ohyeah, thank you for never ever driving drunk, stoned, or otherwise impaired (***** may count in some cases).
  5. sociallydistorted
    sociallydistorted
    Well I'm in the Marine Corps so drunk, stoned, or otherwise impaired driving is totally out of the question for me.
    Two grounds is a good idea though. Thanks
  6. pasadenahotrod
    pasadenahotrod
    from Texas
    AND thank you for your service to your country and all of us!
    SALUTE!
  7. Casey
    Casey
    I`ll bet you a case of beer ! it`s the bendix spring that broke ,
    pull the starter before you waste any time on anything else !
    it`s happened to me twice playing with flatheads over the years.
    every thing just binds up and will not do anything.
    oh yea , pull it out just a little bit put a 5/16 nut on the long starter bolt to hold it all together it`s a real time saver.
    before you take it all the way out it`s a ***** getting the brushes back together if you let it slip apart.:) and thank`s for serving.
  8. sociallydistorted
    sociallydistorted
    I appreciate the help and support fellas. I'm off to get my hands dirty on it.
  9. sociallydistorted
    sociallydistorted
    ok, so I finally got enough time to take a look at it and I double checked all of the ground wires; All good. Checked for corroded wires; all clean. Tried to start it again and noticed that the ground wire from the battery and the wire running to the starter are hot as ****. Is my starter done?
  10. flatheadjohn
    flatheadjohn
    I'd say your starter is toast and the brushes have worn down to the point they are grounding out. It's time to pull the starter and replace it.
  11. Casey
    Casey
    it`s still the bendix spring !
  12. Joe King
    Joe King
    pull the starter I bet ya a dollar it's jammed
  13. phat rat
    phat rat
    if by chance it is jammed you could put it in gear and rock it that will usually pop it free
  14. sociallydistorted
    sociallydistorted
    Very well, I was hoping I wouldn't have to take this sum***** apart. Just curious, where in the hell am I going to find another bendix spring for a '49 Merc flathead? Like I said before, I'm no whiz with these things.
  15. zibo
    zibo
    from dago ca
    I doubt its the spring.
    Usually when they get stuck the teeth have worn down.
    It'll probably not come out easily.
    TP
  16. Casey
    Casey
    I would ask on the hamb if anyone had one around you first !
    I think they are the same for all the big flatheads
    mac`s, obsolete ford part`s, hell napa . should be able to get you one
    1939 thrue 1953 . should work .
    order 2 of them it`s a good part to carry with you.
  17. T_Bird Guy
    T_Bird Guy
    I work at a local parts store and the springs are still available. The springs are not used on just fords. I broke one on my car, I had a few spares. I heard that the springs break easier if the car is converted to 12 volt.
  18. sociallydistorted
    sociallydistorted
    Casey, you have been a huge help. Thanks a lot man.
    Everyone else as well. I appreciate it.
  19. Casey
    Casey
