Flathead Oil Filter
Discussion in 'The Hokey Ass Message Board' started by titanmike, Jan 4, 2010.
  1. titanmike
    titanmike
    from Covina, Ca
    Can anyone describe where to hook up the filter on a 49-53 flathead and which direction the oil should flow through the filter. i imagine the output from the motor is where the extra pipe plug is next to the oil pressure sending unit and the input to the motor could be on the drivers side of the block. there is a plug there also that would let the oil drain back into the motor but I am not sure which direction it should go through the filter.
    Any suggestion would be greatly appreciated.
  2. V8 Bob
    V8 Bob
    You are correct that the input to the filter is from the port next to the oil sender-these ports are common. The oil then goes to the pasenger side of the filter housing through a special 90* fitting that has a .040"-.060" restriction built into it, limiting the flow into the filter. The oil leaves the housing from the bottom and goes to that 1/8" pipe access in the block on the drives side. 1/4" brake tubing can be used if mounted on the left head as stock, but flexable hose has to be used if you remote mount the filter.
    Bob
  3. greazhonkey
    greazhonkey
    Like V8 Bob said, use rubber hose or a rubber link on a hardline if you remote the filter. Very,very important.
  4. titanmike
    titanmike
    from Covina, Ca
    Thanks for all your help V8 Bob. I take it that the .04" - .06" hole is to prevent too much oil from going to the filter and not enough going thru the motor?
  5. Asphalt Outlaw Hero
    Asphalt Outlaw Hero
    from Dixie
    I was talking about this with a guy who builds cars.
    His opinion was that on a flatty,ditch the oil filter.Maybe put a magnet on the bottom of your pan and change the oil often.
    Oil filters pull 5LBs of pressure.
  6. V8 Bob
    V8 Bob
    ***anmike,
    These filters are partial-flow in design, in that they filter a small amount of oil with a very fine filter, so eventually all the oil does gets filtered over time. There are pros and cons of this design and I'm not going to debate them, except that they are better than no filter. IMO.
    Bob
  7. titanmike
    titanmike
    from Covina, Ca
    Thanks Bob. IMO any filter is better than no filter.
  8. pasadenahotrod
    pasadenahotrod
    from Texas
    The restriction in the line keeps the oil pressure in the engine up to standard.
  9. titanmike
    titanmike
    from Covina, Ca
    Thanks everybody for all your help. Filter is mounter to the engine and plumbed in hard line.
