flathead oil filters
Discussion in 'The Hokey Ass Message Board' started by lincolnlog, May 10, 2007.
  1. lincolnlog
    lincolnlog
    from Arizona
    hey folks,
    I was wondering where all of you guys are getting your flathead oil filters. i just changed mine yesterday, and the one i got from so-cal was JUNK compared to the fram i pulled out. I am almost hesitant to put it in the car. Also, if anyone has any leads on the BIG filter (Fram c4n) for the 337 that would also help out a lot.
  2. yblock292
    yblock292
    OPPS, just got a big one and cut it down to the standard size, but i bought a case of filters from Oreillys, they had to order them for me, didn't seem like it was any big deal.
  3. Bruce Lancaster
    Bruce Lancaster
  4. lincolnlog
    lincolnlog
    from Arizona
    o'reilly's eh? i'll have to look into that. as for that other filter posted, mine is not so much tall as larger diameter and only slightly taller than the more common flathead type.
  5. 47bob
    47bob
    I solved that problem. I took the whole damn thing off and threw it across the yard. They don't work worth a shit anyway. Just change the oil more often.
  6. Flat Ernie
    Flat Ernie
    Tech Editor
    I get 'em at the local Checkers - Fram C4P or C4
  7. Brian C
    Brian C
    I've been using the NAPA part number: 1010 in their "gold" line.
    The local parts guys sez it's actually made for a mercedes. I figure it's an upgrade for the filter to be used in a flattie.......:D
  8. HotRodFreak
    HotRodFreak
    The cannister will function better as a beer mug.
  9. Brian C
    Brian C
    Uuummmmmm
    Doesn't the oil sorta make the beer taste like Crap! :rolleyes:
  10. Automotive Stud
    Automotive Stud
    I've been using the napa 1006 in my flathead no problems. They always have 1 or 2 in stock here.
  11. HotRodFreak
    HotRodFreak
    Doesn't the oil sorta make the beer taste like Crap! :rolleyes:[/quote]
    DUH..... clean it first.
    Be the first on your block.
  12. i used wix in my customers woody wagon.
    wix #51006
  13. Automotive Stud
    Automotive Stud
    Sounds right. Wix and Napa use the same # cause it's the same company, but napa drops the 5- prefix on all thier packages.
  14. 64 DODGE 440
    64 DODGE 440
    from so cal
    Just put a Frantz on it and buy a case of toilet paper.:)
