Technical Flathead oil pan
Discussion in 'The Hokey Ass Message Board' started by moskit, Apr 20, 2016.
  1. moskit
    moskit
    from London
    Hi guys.
    Bough 8CM merc Flathead but the guy who sold it to me said that he lost oil pan for this motor.
    Will EAC or 8BA pan work?
    Unless any one in here might have spare PAN/SUMP for merc and want to sell it.
    Thank you
    Sent from my ALE-L21 using H.A.M.B. mobile app
  2. drtrcrV-8
    drtrcrV-8
    Yes, either pan will do, as the blocks don't care what letters are on the heads. It's the same block casting, just different crank, pistons, cam, heads, & manifold.
  3. V8 Bob
    V8 Bob
    It may depend on what ch***is you are installing the engine in. The 8CM and truck pans are rear sump, while the 8BA, EAC and EAB are center sump.
    Atwater Mike likes this.
  4. Bruce Lancaster
    Bruce Lancaster
    And to swap you need pickup tube to match pan...Merc and truck use a short one for the rear sump, Ford cars and post-'52 Merc need longer tube. Real question is what ch***is is engine going into and where its obstacles like steering linkage are.
  5. webb1932
    webb1932
    I have an 8cm pan and correct tube and dip stick. bwebb7230@gmail.com
  6. V8 Bob
    V8 Bob
    JFYI, your pan is center sump '52-'53 Mercury EAC and Ford EAB. The Merc 8CM is a rear sump.
  7. webb1932
    webb1932
    V8Bob Thanks for the I D It came off of of a 52 Merc. that's why I sent pic to see if member could use it. Bill
  8. Jimmy2car
    Jimmy2car
    from No. Cal
    Where is London?
  9. moskit
    moskit
    from London
    London is in United kingdom ;-) i have EAB sump currently but thanks guys for helping me out
  10. Duh'Oh have the schools gone that far down in NorCal since the '60s? :D :D
    Sorry I just couldn't resist. :eek: :D
