Hot Rods Flathead oil pressure question
Discussion in 'The Hokey Ass Message Board' started by WiredSpider, Aug 6, 2021.
  1. WiredSpider
    WiredSpider
    I,m curious what is normal oil pressure for a flathead Ford.
    I recently built a 59A with a mellings high volume oil pump and have a persistent rear main leak.
    I,m wondering if I have too much oil pressure(65 psi at highway speed) and I,m curious if I have to shim the pressure byp*** in the valley and if so by how much.
    I have already changed the rear main seal once and I,m wondering if i,m doing a ****ty job or if it is something else
    Thanks
  2. walter
    walter
    That's a lot of oil pressure. I have 40 psi @ 2500 rpm and 20 psi @ 800 rpm
    210superair likes this.
  3. tubman
    tubman
    The spec is 55 psi at speed. I generally see 25 psi warm idle and 55 psi on the road on a properly built engine.
    BTW, I have had nothing but trouble with high pressure/high volume oil pumps in stock rebuilds; they are only needed in racing engines with larger than stock clearances. This is one case where my signature line does not apply.
  4. Dirty Dug
    Dirty Dug
    Having oil leak from the rear seal of the pan indicates it's flathead.
    stillrunners, hfh, The 39 guy and 5 others like this.
  5. SEAAIRE354
    SEAAIRE354
    I’m with Tubman. Rule of thumb is 10 lbs pressure for every 1000 rpm.
  6. 210superair
    210superair
    from Michigan
    When I first got my car I asked a buddy what kind of oil to use. He said "in a flathead? Something that matches the floor of your garage...", lol. Mine doesn't leak tho, maybe a drip now and then.
    I'm also at 15-20 at idle, 45-55 flyin down the road. It was higher when I ran Rotella in it like some idiot told me to do, and this idiot listened to him. Switched back to 10/30 and the oil pressure got right again....
  7. WiredSpider
    WiredSpider
    I,m running 20/50 Valvoline VR1.
    Maybe I,ll try a different oil.
    The thing is that I have another engine with the same oil pump and it,s oil pressure isn,t as high
  8. Model A Gomez
    Model A Gomez
    I'm running an 8BA with a high volume oil pump, 20/50 VR1 oil and when it's warmed up it's about 20 at idle and 40-45 psi at highway speeds. I also have a slight drip at the rear of the pan but didn't RTV the rear gasket where the pan sits. Only about 600 miles on it so far but happy with the oil pressure.
    Desoto291Hemi likes this.
  9. SEAAIRE354
    SEAAIRE354
    I’m a fan of the VR 1. I use it in a lot of older vehicles I maintain. They do make it in 10-30 if you wanted to try it. As far as the other engine running lower pressure with the HVpump,it may have looser bearing clearance. 65 psi with a HV pump sounds about right with proper clearance.
  10. flatjack
    flatjack
    Oil pressure has no effect on a properly installed rear seal.
    jimmy six, Desoto291Hemi and 6sally6 like this.
  11. 6sally6
    6sally6
    ^^^^^^^^^^ I agree!
    6sally6
  12. When the flathead stops dripping ,you know your down a quart !!
  13. WiredSpider
    WiredSpider
    I thought the higher pressure might be pushing the oil past the seal
  14. jimmy six
    jimmy six
    Oil leaks will slowdown or stop with the installation of a PCV system even on an old style engine that never had one. Personally I believe today no engine needs 20-50 oil built to drive on the street or should be built to need it.
    SEAAIRE354, stillrunners and tubman like this.
  15. tubman
    tubman
    I really hate to suggest modern updates to cl***ic (flatheads, of course, are) but in the case of the later (8BA) engines, I will suggest going to a PVC system (properly done) rather than the traditional "draft tube. I will create a slight vacuum in the crankcase, (rather than a slight amount of pressure), which will solve a lot of leak problems.
    (Ooops; great minds run in the same channels.)
    SEAAIRE354 and jimmy six like this.
  16. Blues4U
    Blues4U
    from So Cal
    I didn't think so. The seal is sealing against crankcase pressure, not oil pressure.
  17. Blues4U
    Blues4U
    from So Cal
    I don't think so, the seal is not sealing the oil into the bearings, it's sealing against pressure in the crankcase; that's why the other guys mentioned adding a pcv system, to alleviate the crankcase pressure.
  18. Street Is Neat
    Street Is Neat
    Pressure release spring in oil valley not opening . anyone else thinking along those line
  19. stillrunners
    stillrunners
    from dallas
    Jimmie said it - that was what I was going to ask if it still has the stock tube breather on it ?
    WiredSpider likes this.
  20. WiredSpider
    WiredSpider
    yes it does
  21. tubman
    tubman
    I'm with you; that's the limiting factor. If the proper spring is installed, there should be no way the pressure can be too high.
    Of course, it's hard to predict the properties of an "extra capacity" oil pump.
