flathead oil pressure
Discussion in 'The Hokey Ass Message Board' started by showkar, Feb 11, 2012.
  1. showkar
    showkar
    from michigan
    my 53 merc flatmotor has great oil pressure (around 55 lbs when driving)
    running strait 50 weight oil. problems come in at idle, dropping to
    around 5 lbs. when good and hot. any input? engine has around 800 mi.
    thanks for your input showkar
  2. flatheadpete
    flatheadpete
    from Burton, MI
    Your good. As long as it has pressure.
    BTW, Where ya from in our crappy snow filled state? Any pics of your car?
  3. 296 V8
    296 V8
    from Nor~Cal
    Sounds a bit low for a fresh motor but flatheads are kinda known for low presser at idle….if there's no metal in the oil and no bad noises I wouldn’t worry.
  4. flatheadpete
    flatheadpete
    from Burton, MI
    Have you changed the oil yet? If not, DO IT! And again in about 5-700 miles. Hopefully it's clean and not metallic.
  5. Special Ed
    Special Ed
    Sounds about right. I personally wouldn't be too concerned. My rebuilt Lincoln flathead ran identical to what you described, and is still running fine, twenty years later....
  6. Mike51Merc
    Mike51Merc
    Why would you run straight 50W in Michigan?
  7. 19Fordy
    19Fordy
  8. alv
    alv
    from jackson,NJ
    i have a 1937 ford phaeton with stock motor oil pressure is about the same and i run straight 30w change every 500 miles. also have a filter that filters some of the oil.
  9. I would run 20 w 50 Castrol as mentioned above and add a small amount of Marvel Mystry oil to it.
    Frenchy
  10. showkar
    showkar
    from michigan
    hey, thanks for all the input, new address is florida, michigan winters suck.
    i run strait 50# valvoline racing oil, was thinking of streching oil pump spring
    guess i will leave it alone, dont need anymore oil pressure at driving speed.
    thanks again
  11. outlaw256
    outlaw256
    well im glad you posted this question up here. now i wont have to ask. ive got 8ba that i got running awhile back. first crank up it runs about 40 or more then after it gets warm it drops to around 5. so nowi feel alot better. i cant afford to rebuild one of these right now.a sbc they aint.damn near build 2 sbc for one flatheaD, but god they sound good dont they!!!
  12. gaspumpchas
    gaspumpchas
    Long as you show some oil pressure at idle you are good. I'd try 15w/40 Diesel oil, like Rotella, this stuff is liquid Ball bearings...saved an old 305 chevy I had, doubled the op by changing to this...good luck!!
    "Binkys Pizza.......
    "Hey man--u got any more o' them secret agent spy scopes?
    "Hit parade on the Stethoscope?"
    "you got the wrong number partner....."
    gaspumpchas:cool:
  13. Shopking
    Shopking
    from central Pa
    Hey,update your location in your member profile.Florida a good place to live this time of year.Im jealous
