Technical Flathead one piece crank oil seal orientation
Discussion in 'The Hokey Ass Message Board' started by Chappy444, Oct 7, 2020.
  1. Chappy444
    Chappy444
    Hello all,
    Getting read to install the one piece crank seal on my flathead.
    I noticed that there is a difference in the profile on each side so I am ***uming there is a preferred orientation.
    The "peak" on the seal has a flat ridge on one side and does not have it on the other side. I am ***uming the ridge side faces the block but wanted to be sure... really don't want to have to take it apart again later to fix a leak.
    Thanks for the help.
  2. lothiandon1940
    lothiandon1940
    back up for chappy.:)
  3. triumph 1
    triumph 1
    The inside lip of an oil seal always faces in
    So by looking at your pics the bottom picture should be facing in to the block.
    Hemi Joel likes this.
  4. 38jon
    38jon
    from York,PA
    What triumph said, but pull the rubber jacket off the seal and silicone a small bead inside of sleeve and stretch it back over seal, also silicone both grooves that seal sits in, recently installed same seal and didn’t silicone and it leaked.
  5. Cliff Ramsdell
    Cliff Ramsdell
    Chappy,
    Pic 2 looks to be the correct inside of the seal. I installed the same one and had no issues with leaks.
    Cliff Ramsdell
  6. Chappy444
    Chappy444
    Thanks all for the responses.
    I really appreciate it!
    Chappy
    lothiandon1940 likes this.
  7. Aaron D.
    Aaron D.
    This may be of some help.
