Technical flathead pertronix question
Discussion in 'The Hokey Ass Message Board' started by COOP, May 4, 2016.
  1. COOP
    COOP
    My A V8 roadster has been setting since last year due to a spark issue. Just picked up a pertronix unit and installed it. This is a '47 59L engine. The installation went fine.... fire up went fine.... but there is a severe hesitation when I stab the gas pedal. The point system did not do this at all. I moved the timing tab from one end of the slot to the other and has no effect. Is this normal for this unit? I checked the vacuum advance brake and it seems to be operational. (hard to check) If there is any experience out there I would appreciate feedback. On another note the spark energy that comes out of this thing will buckle your elbow. I get almost a 1" arc that you could darn near weld with. The engine fired up with about a 1/2 roll over. Now if I can get it to run right I'll be tickled.
  2. The PerTronix is not causing your hesitation - If it is firing (as it must be since it is running) then the issue has to be one of timing IF you did not change Anything else.
  3. nickleone
    nickleone
    When we installed a PerTronix unit on the 62 Rambler 6 the timing changed.
    Look at that first as suggested.
    Nick
  4. COOP
    COOP
    I didn't mean to imply that it was the unit causing the problem, but the installation. There is no mention of any problem solving solutions. Like I said, I moved the timing mark from one end to the other and no difference. I was hoping to hear from someone that has installed one to see what or if ,I did anything wrong.
  5. old sparks
    old sparks
    have one on a 46 flathead in my Austin coupe. had trouble with it dying at a stoplight for no reason and then starting right back up, also a hi ( for a flathead ) rpm miss. found the coil polarity reversed due to not paying attention on the install. The thing that fixed all problems was running a #10 wire for the ignition supply using a 30 amp relay instead of routing power thru the ignition switch. The ignition switch now powers the relay. Hope this gives you some things to look for.
