Technical flathead piston clearance
Discussion in 'Traditional Hot Rods' started by fluxxnoise23, Nov 11, 2014.
  1. fluxxnoise23
    fluxxnoise23
    from upstate ny
    can anybody tell me what the tolerance limit is on a '51 1BA
  2. Bader2
    Bader2
    40 thou, some say 35 but that can be iffy.
  3. joel
    joel
    If you mean piston to head clearance, most guys on the Fordbarn say .050". For piston skirt clearance, my Motors manual says 10 lbs pull on a .003" shim for a steel piston and 10 lbs on a .0025" shim for aluminum. These are the tightest fittings.
